- Thank you received: 72
primary chain wear limit
- turboguzzi
07 Oct 2010 14:01 #404985
by turboguzzi
primary chain wear limit was created by turboguzzi
trying to find the wear limit for the primary hyvo chain in a 750 but the manual doesnt give one...
does anyone have a clue, say max allowed distance between 20 links or something?
thanks
TG
thanks
TG
- cafekz750
07 Oct 2010 14:39 #404990
by cafekz750
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Replied by cafekz750 on topic primary chain wear limit
- wargoth
- Thank you received: 2
07 Oct 2010 14:39 #404991
by wargoth
Replied by wargoth on topic primary chain wear limit
Chiltons says:
"with the crankshaft and the secondary shaft in place, check the primary chain slack. Replace the chain if slack exceeds 27mm/1.08in."
the replacement is a tsubaki hy-vo 3/8p-1w 76 link chain
Laying a straight edege over the outside of the chain and measure deepest point with a ruler would probably work best
- wargoth
07 Oct 2010 14:41 #404992
by wargoth
- cafekz750
07 Oct 2010 14:42 #404994
by cafekz750
- steell
08 Oct 2010 13:21 #405232
by steell
Replied by steell on topic primary chain wear limit
If you need a new one, check out the chain for a early eighties Honda CB900C. IIRC, it's the same chain and an awful lot cheaper than the Kawasaki chain (if it's even available)
- Injected
- Thank you received: 543
09 Oct 2010 08:30 #405452
by Injected
Replied by Injected on topic primary chain wear limit
The KZ chain is still available but the Honda chain is $60 cheaper - worth a trip to the Honda store!
- turboguzzi
12 Oct 2010 08:40 #406124
by turboguzzi
Replied by turboguzzi on topic primary chain wear limit
thanks guys, measured and i am only at about 16mm free play, so that's good.
steell
seen your into 750 motors, I am building now a gpz750/810 for vintage racing, looking for detailed info
got time and will to help?
PM me...
steell
PM me...
- gpzman2000
13 Oct 2010 12:22 #406376
by gpzman2000
Replied by gpzman2000 on topic primary chain wear limit
What's the word on primary chain durability ?
I have about 38k miles on the original.
