Thanks to all and more questions.
- kawa
06 Oct 2010 20:43 #404726
by kawa
Thanks to all and more questions. was created by kawa
I bought a 1980 KZ 1000 shaftie in June 2009 not running but souper clean.The reason it was left aside was it was not charging. I laid down $500 bucks and it sat next to the KLR for a year. with the help of you I took it down clean the carbs replaced the rectifier and other maintenance it is awesome 170 miles.Noticed it is leaking oil out the chrome cam cover. I also snapped the clutch cable today so I will take it down and replace the cable and VC gasket.I have been able to get most of this done without posting(site rocks. I Am confused about best way to replace acoording other post.IE,sealand around the chrome caps or where to put tack. More sugesting please?
- Nebr_Rex
- Thank you received: 300
06 Oct 2010 20:53 #404731
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Thanks to all and more questions.
1194,(the grey stuff)very thin coat both sides of gasket.
Others might dissagree,but thats my opinion and mine does'nt leak.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 Oct 2010 07:43 #404834
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Thanks to all and more questions.
Any high temp rated permatex gasket maker is fine, I like moto-seal myself as it is thin and easy to apply, and stands up to the heat.
The end caps can be wrapped 6-7 times with teflon plumbers tape before installing. Clean all gasket surfaces with a high flash point solvent. Apply a very thin coating to both gasket surfaces. By very thin, I mean just smear it on there with a fingertip, like less than 1mm thin.
Than seal her up and use the recommended torques for the cover bolts. Run the engine till warm, then let cool completely for an hour, and re-tighten.
Do it, just DO IT.
Do it, just DO IT.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2829
07 Oct 2010 07:56 #404838
by 650ed
Replied by 650ed on topic Thanks to all and more questions.
DO NOT apply sealant to both sides of gasket! Apply only to the top side so it sticks to the valve cover or apply none to either side. Ed
