- Thank you received: 20
ThinkigExhaust valve timing
- nads.com
- KruZer
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- Rickman
- Thank you received: 1
However nads, I think you missed out on telling us what you're trying to resolve. Moving exhaust cam timing affects overlap, if you have any; I'm not educated enough to state what the results could be against intake velocity and cylinder fill.
don't you need enough duration on the exhaust opening, so you have emptied the cylinder enough before opening intake?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- hocbj23
- Visitor
Yeah,but William Burroughs wrote "Naked Lunch" ,Nads however is just "out to lunch".bjI like nads.com, he makes me think. But then I like stream-of-consciousness authors like Burroughs.
- PLUMMEN
- Thank you received: 104
- KruZer
Buzz
- larrycavan
- Visitor
Ben's head is flowing 91CFM at 10" at .400 lift with 89% throats of J intakes and 35mm bowl.... and the runners are smaller than stock J runners.... We'll see if yours will top that....
Smoke 'em if you got 'em.......
:woohoo:
