Need help with engine build up!
  • CruisingRam
  • CruisingRam's Avatar Topic Author
Re: Need help with engine build up!
22 Apr 2006 00:21
#41599
Bumpage? :P
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
  • wireman
  • wireman's Avatar
22 Apr 2006 03:50
#41606
what are you doing to head and carbs?;)how is bike going to be ridden?
Post edited by: wireman, at: 2006/04/22 07:04
  • Max2022
  • Max2022's Avatar
22 Apr 2006 04:12
#41607
In my opinion the most power your going to get out of a stockish engine will be found in the drivetrain. Invest in good sprockets, race chain, spend a good amount of time precisley tuning the chain slack, etc.. What point is there adding 5 or 6 hp if your going to lose it at the chain?
Aluminum sprockets hold up pretty good
And I'll be fitting a Regina GP race chain later today, I'll tell you how well it works.
  • CruisingRam
22 Apr 2006 07:25
#41629
wireman wrote:
what are you doing to head and carbs?;)how is bike going to be ridden?<br><br>Post edited by: wireman, at: 2006/04/22 07:04
Mild porting. Carbs are a wild card, I have four sets, I will as wiredgoerge what set is the best and such when that bridge needs to be crossed.
  • reborn650
  • reborn650's Avatar
22 Apr 2006 10:56
#41654
Hey Cruisingram. As far as the porting it is a fairly easy way to improve the breathing of your plant. The trick is not to take off too much, just clean up the rough castings and match the intake runner mouth to the carb boots. Also consider lapping the valves. These are two inexpensive ways to sneak a few extra ponies outta your motor.
Oldkawman has some pics and pointers on his site. Check it out here.
www.oldkawman.com/
Cheers-Colin Firth -Ontario Canada
'77 Kz 650 Custom - (Miss July on 2006 Kzr Calendar,) Newest rebuild includes Wiseco 810 kit, Kz750 cams, Kz750 intake valves, 750 GPz springs, Ported head, WG Mikuni 28's, Velocity Stacks, Dyna Ignition and coils, MAC pipe, 14 tooth sprocket, going back to original '77 Moon Dust Silver. Goal is to have a stock-looking bike that will tighten up any loose dental fillings off the light.
-1998 Jeep TJ Wrangler 4.0...
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
22 Apr 2006 12:01
#41667
Have not done this but have given it some thought.
What about finding a nasty looking kz1100 for cheap?
Rob the pistons, rings, head, and carbs.
You get bigger valves, modern cam profile,
bigger ports, 1189CC, and some increase in compression.
All you'll need to buy are spacer to go under block, camshaft sprockets, idler adapter kit,
and your gasket set. Will have to have your 1015 block bored for the
larger pistons.
-Duck
Post edited by: Duck, at: 2006/04/22 15:02
  • CruisingRam
23 Apr 2006 03:25
#41801
Notice us being mechanical geniuses
  • Duck
  • Duck's Avatar
23 Apr 2006 04:35
#41805
Yep, one would almost think you're a couple of Canadians.
