NEED HELP Fixed starter now bike won't move
- chrisd
02 Oct 2010 19:19 #403577
by chrisd
NEED HELP Fixed starter now bike won't move was created by chrisd
i have a buddy that has a kid work on his bike in school a few years ago. anyways he fixed the starter ans now the bike wont move. i took the cover apart and looked at the clutches they don't seem wore at all. the back tire will turn over until you let the stand down. j/w if something wasnt put back together right or if the springs on the clutch are bad. thanks for your help.
- PLUMMEN
- Thank you received: 104
02 Oct 2010 19:24 #403580
by PLUMMEN
Replied by PLUMMEN on topic NEED HELP Fixed starter now bike won't move
what kind of bike? :blink:
- larrycavan
- Visitor
02 Oct 2010 19:25 #403581
by larrycavan
Replied by larrycavan on topic NEED HELP Fixed starter now bike won't move
Ahhhhh.....this needs a little more clarity to have any hope of figuring out what's up.
Bike?
What do you mean by wheel turns until you put the stand down?
Many kawasaki bikes have side stand switches that will kill the motor if you put the bike in gear with the side stand down.
Bike?
- chrisd
02 Oct 2010 19:28 - 02 Oct 2010 19:32 #403583
by chrisd
Replied by chrisd on topic NEED HELP Fixed starter now bike won't move
it is an older kawasaki 750 i had the wheel stand down not the kickstand
Last edit: 02 Oct 2010 19:32 by chrisd.
- PLUMMEN
02 Oct 2010 19:30 #403586
by PLUMMEN
what did he do to the bike?
- chrisd
02 Oct 2010 19:33 #403587
by chrisd
something with the starter not 100% sure. the bikes not mine a buddy just asked me if i could firgure out why it wont move
- larrycavan
- Visitor
02 Oct 2010 19:34 - 02 Oct 2010 19:38 #403588
by larrycavan
Last edit: 02 Oct 2010 19:38 by larrycavan.
- chrisd
02 Oct 2010 19:40 #403592
by chrisd
if you put it in gear the wheel will turn but if it on the ground it wont like the clutches are slipping. before he worke on it it had no issues with the clutches
- PLUMMEN
02 Oct 2010 19:46 #403594
by PLUMMEN
have you tried adjusting clutch cable,will bike go into gear?
year and model would really help
- chrisd
02 Oct 2010 19:52 #403599
by chrisd
it is a 1981 kawasaki 750 i havent messed with the clutch cable. it goes into gear just fine
- larrycavan
- Visitor
03 Oct 2010 06:31 - 03 Oct 2010 06:32 #403677
by larrycavan
Agree 100% with you Jim.
Put some free play in the clutch adjustment.
Whatever is wrong has nothing to do with the starter motor.
Sounds to me like someone tried to adjust the clutch and FUBAR was the result
Last edit: 03 Oct 2010 06:32 by larrycavan.
