KZ 650 Hard to start
- AnthonyKiser1977
27 Sep 2010 15:30 #402290
by AnthonyKiser1977
KZ 650 Hard to start was created by AnthonyKiser1977
I have a 1977 KZ 650 that I performed a motor swap on and now I can't get it started. I checked for spark and it has spark. After kicking it over for a few minutes fuel leaks out of the bottom of the carbs, but when I check the plugs they are gas soaked. I will purchase some new plugs and try it again later. After several kicks the motor put out a sputter and then died. Any help is greatly appreciated.
- Thank you received: 2829
27 Sep 2010 16:03 #402293
by 650ed
Replied by 650ed on topic KZ 650 Hard to start
If you haven't done so, make sure the float valves aren't sticking and causing the overflow condition along with flooding the engine. Also, remember when starting - choke on / no throttle. Ed
- TeK9iNe
- What did you do!?!
27 Sep 2010 16:44 #402296
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic KZ 650 Hard to start
650ed wrote:
+1 Sounds right. Carbs are overflowing, causing engine flooding when trying to start. Good info.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- AnthonyKiser1977
27 Sep 2010 18:58 #402336
by AnthonyKiser1977
Replied by AnthonyKiser1977 on topic KZ 650 Hard to start
I tried different plugs and continued to kick start the bike. After a few kicks it would run for a couple of seconds and then die. After kicking awhile longer it ran again for a couple of seconds and then died again. I will check the plugs again later.Thanks for all the help.
27 Sep 2010 20:09 #402354
by 650ed
Keep in mind the plugs aren't getting wet on their own. The fuel can only be coming from the carbs. If you stop the overflow condition first, you very likely will find theproblem keeping it running will be solved as well. In any event, you will need to stop the overflow condition, so why not start there? At this point, you should also check the oil for gasoline smell as you may have dumped enough fuel into the cylinders to contaminate the oil. Ed
- AnthonyKiser1977
27 Sep 2010 20:13 #402357
by AnthonyKiser1977
I just checked the spark plugs and they're dry. The wet plugs must have been from trying to start by adding gas to the cylinders through the plug holes. Anyways now the plugs are dry after attempting to start. Tomorrow I'll look at the carbs, but they were recently rebuilt. Thanks for all of your help.
