- Thank you received: 12
Drive chain length??
- lewisj
27 Sep 2010 10:34 #402246
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
Drive chain length?? was created by lewisj
I have replaced my Z1's swingarm with a Suzuki GS 1100 swinger and 17" rear wheel. The front sprocket is the stock 15T (630 chain) and I have 2 rear sprockets, a 33T and a 35T. Any idea as to what length chain I will need with this set-up? I know many forum members have done the swingarm switch and may have this information already. I may just need the stock Suzuki 96 link chain?
Thanks in advance.
Jim
Thanks in advance.
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- TeK9iNe
- What did you do!?!
- Thank you received: 28
27 Sep 2010 16:46 - 27 Sep 2010 16:47 #402297
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Drive chain length??
just do a mock setup, and use a tape measure to determine length, then add 1 link.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 27 Sep 2010 16:47 by TeK9iNe.
- kz1k
- You Cant Fix Stupid!
30 Sep 2010 18:42 #402997
by kz1k
1978 KZ1000A2
Replied by kz1k on topic Drive chain length??
use a string and buy one a little bigger....you can always take links out. good luck.
1978 KZ1000A2
