- Thank you received: 3
stock sprockets for '79 KZ1000
- Lazyman06
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- z1kzonly
- Thank you received: 540
I know there is a thread about the 530 conversion.
But i need to buy a 5/8 offset 530.
I want a higher ratio 14/37 for 630. which is 2.64 to 1.
This is what I used in the past on a Z1900 14/37.
Fun, pulled the front wheel up in 3rd gear.
How should I figure the countershaft for 530 chain?
15 - 16 - 17 tooth? even 18 tooth?
I know diameters are smaller for 530. Smaller diameters create more heat. But this a short distance bike.
I need it for a street, drag bike with a stock motor.
Going to use a cone sprocket with outboard bearing.
I am using a Harley V-rod rear rim, they are nice 5.5 x 18. 180 tire. It takes a Sportster sprocket, so I can get any size rear.
Just wondering on the counter shaft.
Thanks for any opinions.
Marty
- z1kzonly
5/8 offset with bearing cone.
Marty
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Lazyman06
- z1kzonly
The exact same ratio in a 530 setup would be 18/42. This would make the sprockets exactly the exact same size. The chain required would be 110 link in a 530. Z1E has all of this in stock or can get it very quickly.
Thanks for the info, I'll check Jeffs website.
Marty
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
www.americanclassix.com/streetfighter_conversions.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
