78 Z1R numbers
  • jvette65
  • jvette65's Avatar Topic Author
78 Z1R numbers
24 Sep 2010 13:44
#401474
I am buying a 78 z1r and need to know if the vin # match the engine #? What should they be? How does it affect value? Any info would help.
  • Jack
  • Jack's Avatar
Re: 78 Z1R numbers
24 Sep 2010 13:51 - 24 Sep 2010 15:11
#401475
This question comes up a lot. Matching numbers does NOT mean the engine & frame serial numbers are the same digits. It means the engine and vin( frame) numbers match the numbers the bike left the plant with. It's not unusual to see the frame and engine numbers be 200 - 500 apart in Z1/KZ 's.I've only seen one or two with same digits frame & engine numbers.
Good resource to check is www.zedder.com . Brand/Model and cc.& year-the vin & engine serial number ranges used are listed.Pretty reliable checking my bikes/cases so far.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 24 Sep 2010 15:11 by Jack.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: 78 Z1R numbers
24 Jun 2014 21:00 - 24 Jun 2014 21:23
#637932
Old thread revival......
So to be sure, the Z1-R numbers should fall within a range of 500 or so, correct? What about the other models and years....1978 A model for example, 1979 A model? Basically all kaws from '73 through '80 should have engine and frame numbers within about 500, is that correct?
For example, based on the Zedder info shown below, this Z1-R would NOT have the original engine, right?
Frame Number KZT00D-015200
Engine Number KZT00DE017100
From Zedder:
Year & Model '78 KZ1000-D1:Z1R
Frame No. Range KZTOOD-000101 - 017392
Engine No. Range KZTOODE000101 - 017412
Thanks!
The Kaw List:
Last edit: 24 Jun 2014 21:23 by 79MKII.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: 78 Z1R numbers
24 Jun 2014 21:31 - 24 Jun 2014 21:32
#637934
Wow, I guess I'll just ask the above question about the '78 Z1-R. I just realized that the '79 MKII can't even be close to that range, according to Zedder. They are way off!
Year & Model '79 KZ1000-A3A MKII
Color(s) (1) Luminous Navy Blue
(2) Luminous Dark Red
Frame No. Range KZTOOA-519538 - 523550
Engine No. Range KZTOOAE081569 - 090730
The Kaw List:
Last edit: 24 Jun 2014 21:32 by 79MKII.
