- Thank you received: 1
Engine Oil that has never let me down.
- Capt America
- Born Bad
23 Sep 2010 01:54 #401103
by Capt America
I've used this for as long as I can remember, never had heat problems, never lost a motor to wear, never had it come out any different than it went in, very durable oil IMO.
Long as it's around here's a link that should help anyone unfamiliar with motors in general and first time motorcycle owners.
www.castrolmoto.com/en/trizone/trizone_explained.php
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Engine Oil that has never let me down. was created by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- oldcoldankles
23 Sep 2010 07:42 #401139
by oldcoldankles
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
Replied by oldcoldankles on topic Engine Oil that has never let me down.
That's what I've used too in both bikes for the past 7 years. Never had any problem either, and wear residuals are very low as verified by used oil testing. I get it at Canadian Tire or WalMart.
Peachland BC
1981 KZ1000 CSR M1
1989 Corvette coupe
- TerryK
- Thank you received: 3
23 Sep 2010 07:46 #401140
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Engine Oil that has never let me down.
I use the 20w-50. Great stuff.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Kawickrice
- Thank you received: 18
23 Sep 2010 09:37 #401167
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Engine Oil that has never let me down.
I have used the 20-50 regular grade in everything from lawnmowers to bikes to cars and trucks anything that uses motor oil. I buy it by the case and have done it for years with no oil related or clutch related problems ever. I have used the 4 stroke bike oil before but I normally run the regular oil because keep it stocked up for everything else.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
23 Sep 2010 10:37 #401175
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Engine Oil that has never let me down.
That is a good oil. It is the same formula as their raring oil. A bit expensive for my taste, but you are paying for the name and for a specialty oil.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
- Thank you received: 337
23 Sep 2010 11:13 #401191
by bountyhunter
Replied by bountyhunter on topic Engine Oil that has never let me down.
When I bought my KZ-750 in 1979, the only oil the dealer used was castrol GTX (car oil). I used it for decades. I have 82k miles and still original bottom end. castrol is pretty good stuff.
