Are my lobes right?
  • KZCool
  • KZCool's Avatar Topic Author
Are my lobes right?
22 Sep 2010 06:57
#400819
So I pulled off the valve cover to check the clearances, and i noticed that my lobes were opposite of eachother. not the intake to exhauts, but each cams lobes. does this mean that the cylinders fire separtely? cause I thought they fired at the same time.
1976 KZ750 hardtail
  • KZCool
Re: Are my lobes right?
22 Sep 2010 06:59
#400821
forgot to say that its a 76 kz750 twin.And all the spacings were good but one. its supposed to be .05-.1mm but it was .102, should i still replace it?
1976 KZ750 hardtail
  • Nebr_Rex
  • Nebr_Rex's Avatar
22 Sep 2010 07:06
#400825
750 twin?
Yes.
Wasted spark ignition,it will fire on every revolution.
Spin the engine over by hand after reassembly.
Watch the lobes,they will be facing each other on overlap(that will be at the start of the intake stroke).
And away from each other on the start of the compression stroke.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nebr_Rex
  • Nebr_Rex's Avatar
22 Sep 2010 07:09
#400826
You can get by with it if you don't have the correct shim available,but it should be set to within spec.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • KZCool
22 Sep 2010 08:25
#400847
So they do fire separately?
1976 KZ750 hardtail
  • zed1015
  • zed1015's Avatar
22 Sep 2010 09:15
#400859
yes.
  • TexasKZ
  • TexasKZ's Avatar
22 Sep 2010 09:29 - 22 Sep 2010 09:47
#400862
As I recall, the pistons go up and down at the same time, but one is on a power stroke (just fired) while the other is on the intake stroke, then they do the opposite. Both spark plugs fire at the same time. When the plugs fire, one cylinder is just before TDC on the compression stroke, while the other is just finishing the exhaust stroke and preparing to intake. On the next revolution, the plugs fire again, but the cylinders are on opposite cycles, which is why the cam lobes are opposite. It sounds kinda complicated, but really it isn't.
P.S. When I first saw this thread, I thought you might be e Ferengi! :laugh:
Last edit: 22 Sep 2010 09:47 by TexasKZ.
  • bountyhunter
  • bountyhunter's Avatar
22 Sep 2010 11:55 - 22 Sep 2010 11:56
#400895
On a twin, the pistons move side-by-side but fire at alternating TDC strokes. You get smoother power delivery that way. The spark plugs do both fire at every TDC stroke so there is a wasted spark on each exhaust stroke.
Last edit: 22 Sep 2010 11:56 by bountyhunter.
  • martijn
  • martijn's Avatar
22 Sep 2010 13:18 - 22 Sep 2010 13:20
#400920
they are 180 degrees opposite and since your crank is going twice as fast it's okay:woohoo:
Last edit: 22 Sep 2010 13:20 by martijn.
  • KZCool
22 Sep 2010 15:07
#400949
So is there any actual benifit to this?
1976 KZ750 hardtail
22 Sep 2010 15:18
#400954
KZCool wrote:
So is there any actual benefit to this?
Benefits of wasted spark design include only needing a single coil, and only a single set of points (or other signal), and no need for a distributor.
Spark on combusting cylinder is doing it's job igniting the compressed fuel/air mixture, while simultaneous spark on the other cylinder is wasted.
Good Fortune! :)
22 Sep 2010 15:22
#400957
