- Thank you received: 1
are SOB weight savers and RPM raisers?
- martijn
20 Sep 2010 00:09 #400222
by martijn
are SOB weight savers and RPM raisers? was created by martijn
I'm thinking of changing the buckets for SOB's but does it saver weight (inertia) and thus raising rpm's (less floating valves?)
Does it make sense for a 1200cc kz with 0.395 webcams?
- PLUMMEN
- Thank you received: 104
20 Sep 2010 05:47 #400241
by PLUMMEN
Replied by PLUMMEN on topic are SOB weight savers and RPM raisers?
ask anybody whos ever adjusted valves on a 650 :laugh:
- DoubleDub
- Visitor
20 Sep 2010 07:22 #400265
by DoubleDub
Replied by DoubleDub on topic are SOB weight savers and RPM raisers?
I would hesitate to switch unless I was running cams with a lift that required it (to prevent the shims from being spit off the shim-on-top bucket). Don't believe there is much benefit to them otherwise and makes adjustment a p-i-t-a.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
21 Sep 2010 22:47 #400774
by kzz1p
Replied by kzz1p on topic are SOB weight savers and RPM raisers?
Plummen is right, valve adjustments are much harder.
If I remember correctly, the 650 style valve train is like 30% lighter. It is not worth it for most people.
- martijn
22 Sep 2010 04:32 #400795
by martijn
Replied by martijn on topic are SOB weight savers and RPM raisers?
I do have also a KZ 650 and some engines/heads. I also do have alle teh shims of the 650 and 900. But if it's not worth the effort I'll leave it on top.
Thanks for you input!!
- otakar
22 Sep 2010 05:49 #400805
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic are SOB weight savers and RPM raisers?
I am running SOT on a bike with .420 cams and go to 9500 all the time and have not had any problems at all. The bike has been in this configuration for over two years and runs just fine with SOT. Make sure that you use good valve springs and do not allow the cam gaps to get over spec and you will be fine. With high performance top ends, you have to check and adjust cam gaps more often, using SOB will just make that so much more complicated and difficult. If you want a bit lighter valve train, go to titanium keepers.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
