- Thank you received: 28
Starter clutch idler gear Z1
- nysz1b
- Visitor
19 Sep 2010 09:39 #399883
by nysz1b
Starter clutch idler gear Z1 was created by nysz1b
I'm re-assembling my '73 Z1 motor, and have been using a "Classic Mechnanics" rebuild article, as a guide, along with the Kawa service manual. In the article, it mentions a thrust washer being used on both sides of the starter idler gear. However, this is not shown in Kawasaki's parts list, nor is it mentioned/shown in the service manual. I also do not have this part amongst my parts for re-assembly. Are thrust washers used here, and if so, does anyone out there have a part number? Thanks in advance!
Ken
Ken
- TeK9iNe
- What did you do!?!
19 Sep 2010 11:50 #399961
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Starter clutch idler gear Z1
Just follow the KAW service manual, and you'll be fine.
If you have the actual model info, i can get a diagram and check.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- nysz1b
- Visitor
19 Sep 2010 12:09 #399971
by nysz1b
Replied by nysz1b on topic Starter clutch idler gear Z1
TeK9iNe:
It's a '73 900 Z-1.
Ken
It's a '73 900 Z-1.
Ken
