- Thank you received: 3
good compression?
- Lazyman06
Cylinder
#1 120 psi
#2 120 psi
#3 107 psi
#4 130 psi
The number 3 cylinder is what scares me with all the other cylinders being so high why is number 3 so much different.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
- Thank you received: 2098
ran the compression while ago. tell me what ya'll think.
Cylinder
#1 120 psi
#2 120 psi
#3 107 psi
#4 130 psi
Specs:
Standard 128~156 psi
Service limit 100 psi w/ <14 psi dif b/w cyl
Could do leak-down test to determine where compression is escaping.
- muddy1
- 1980 Kz1000 LTD B4
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- MFolks
- Thank you received: 540
1."Tight Valves", Having clearances that need a thinner shim between the cam(s) and valve bucket.
2.Carbon build up on #3 valves holding them partially open.
3.Stuck piston rings, letting compression go by the piston.
Engine Chemicals:
Mopar Combustion Chamber Cleaner # 04318001. Designed to remove carbon from combustion chambers & valves.
www.amazon.com/Yamaha-Ring-Additive-32oz...-32-00/dp/B002GUCLH2 (Yamaha Ring Free)
- Lazyman06
- TeK9iNe
- What did you do!?!
- Thank you received: 28
there is carbon on the piston so logic can deduct that there is carbon on the valves as well. it setting up as long as it has the rings might need to be set in again. it probably just needs to be ran to work the crap out of it's system
Take her out for an hour or so, then do the compression test. Hot numbers are what matter on the old air cooled stuff, unless the bike is particularily hard to start, and has horrible low numbers cold.
Coul just need a valve lap job. Won't know without further diagnosis.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Lazyman06
