KZ1000 goes into gear but won't move
- bigredkz
17 Sep 2010 15:08 #399377
by bigredkz
KZ1000 goes into gear but won't move was created by bigredkz
I have a 76 KZ900 that I rode last night and the instrument lights went out and now when you put the bike in gear, it won't move. Does anyone have any ideas on what could have caused this?
Thanks
Thanks
- taildragger1197
- Thank you received: 17
17 Sep 2010 15:16 - 17 Sep 2010 15:17 #399378
by taildragger1197
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
Replied by taildragger1197 on topic KZ1000 goes into gear but won't move
Welcome to KZR. This thread may help.
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=385562
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
Last edit: 17 Sep 2010 15:17 by taildragger1197.
- MFolks
- Thank you received: 540
17 Sep 2010 15:28 #399381
by MFolks
Replied by MFolks on topic KZ1000 goes into gear but won't move
To check the sprocket nut for the engine, remove the shifter lever (1 bolt),foot peg assembly on the left side of the engine (4 bolts), the cover for the starter motor(2 bolts) and then the sprocket cover(4 bolts). Some models use phillips head fasteners, others socket head cap screws(Allen type).
The instrument lighting problem may be due to either a blown fuse or corrosion in the fuse clips. Look under the seat around the battery for the fuse holders, some bike's have them with a transparent cover, others are in a black holder.
If the fuses are bad the replacements are the AGX size available at auto parts stores.Probably 10 or 20 amp ratings.
