Well, second gear isn't useful anyways right?
- RsvBruno
16 Sep 2010 12:15 #399117
by RsvBruno
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
Well, second gear isn't useful anyways right? was created by RsvBruno
After all the help from everyone, I have a running KZ1000K that still needs a ton of work, but is at the very least: Drivable. When I found out that second gear is completely non-existent. I've been lurking around reading post after post and it seems that pulling the engine is the only way. I would like to say thanks to you all though for the information needed and letting me know that I will need at least a case of beer or so to do this messy job. On a sidenote though, it doesn't hurt anything to just shift from 1st to 3rd and ride it like it is right?
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
- mark1122
- Keep twisting it
- Thank you received: 109
16 Sep 2010 12:53 #399124
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Well, second gear isn't useful anyways right?
Not if u keep the load down so that u are not lugging bad when u let the clutch out into 3rd.
just change from 1st at a higher rpm then 3rd will be happier.
it will be a little harder on the clutch plates (they will ware faster) but it should not be a big deal. as long as u are not creating a ping or severe load when u start to accelorate in 3rd.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- TerryK
- Thank you received: 3
18 Sep 2010 00:07 #399527
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Well, second gear isn't useful anyways right?
Second is non existent?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Old Man Rock
- Thank you received: 225
18 Sep 2010 07:17 #399568
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Well, second gear isn't useful anyways right?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bikerjim
- 1986 T-type Regal
18 Sep 2010 08:49 #399585
by bikerjim
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
Replied by bikerjim on topic Well, second gear isn't useful anyways right?
Hopefully it is something simple, as the shift drum pin described above.
However, if you just obtained the bike and don't know it's history, it's possible some teeth are missing due to shock when "popping the clutch". Ask me how I know this.
If the debris has fallen to the bottom, you might be lucky enough to drive it, provided you don't hit a pothole/bump which might reingage that debris in the gear train. Then you might be looking at some really expensive repair, if repairable at all. Again, ask me how I know this.
Do what you feel comfortable with.
- APE Jay
- Banned
- Thank you received: 58
18 Sep 2010 09:57 #399612
by APE Jay
Replied by APE Jay on topic Well, second gear isn't useful anyways right?
Second gear is the weak link. If you have to replace it, don't use stock gears.
kzzone.com/trans.html
- muddy1
- 1980 Kz1000 LTD B4
18 Sep 2010 12:27 #399650
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic Well, second gear isn't useful anyways right?
for a little peace of mind, you could drop the oil pan, and have a Look/See
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
