1979 KZ750B twin exhaust pipe diameter
- bikerjim
- 1986 T-type Regal
14 Sep 2010 12:31 #398668
by bikerjim
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
1979 KZ750B twin exhaust pipe diameter was created by bikerjim
Is exhaust pipe o.d. nominal 1 1/2" or 1 5/8"? My digital calipers show 1.59" actual. Wondering which nominal size mufflers to order. Would 1 1/2" have enough slop? Would 1 5/8" have too much slop? Thanks.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
14 Sep 2010 17:57 #398749
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 1979 KZ750B twin exhaust pipe diameter
If your calipers show 1.59, then 1 1/2 would not fit.
I believe 1 5/8 then...
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
14 Sep 2010 18:44 #398776
by Patton
Replied by Patton on topic 1979 KZ750B twin exhaust pipe diameter
Does design of new muffler rely only on a snug slip-on fit, or is it held with a ring clamp?
Shimming and/or hi-temp sealant may be feasible with a slightly oversize ring clamp version.
Where snug slip-on is desired, a muffler shop may likely be able to expand the muffler to a perfect i.d., (which is the ideal solution to V&H muffler>header fitment, and doesn't affect the plating on a chromed V&H muffler).
But too much expansion might crack chrome plating in other applications.
