Oil leak from exhaust
- harrisondr
12 Sep 2010 22:27 #398159
by harrisondr
Oil leak from exhaust was created by harrisondr
My 1982 1000 LTD is leaking oil. It appears at the joint between the exhaust header and the pipe that leads to the muffler. It appears to be leaking down the pipe from the cylinder head. I just had the head gasket replaced along with some other work. Could someone give me a possible diagnosis? Thanks.
- MFolks
- Thank you received: 540
12 Sep 2010 22:54 #398167
by MFolks
Replied by MFolks on topic Oil leak from exhaust
Cable driven tach? These have a rubber seal and "O" ring that gets hard and leaks. Go to
www.z1enterprises.com
and order new seals for your bike.
- Motor Head
- Thank you received: 391
13 Sep 2010 06:28 #398193
by Motor Head
Replied by Motor Head on topic Oil leak from exhaust
Should be an electric tach on that model, same as mine.
How long ago was the top resealed? Has it had a retensioning? Unless it leaked from the start, then this may take care of it. It's recommended after the first couple of heat cycles to to a re-torque of all the bolts.
