750 twin head question
- jake100
12 Sep 2010 07:59 #397987
by jake100
750 twin head question was created by jake100
Will the head from a "B" model work on a"K" model. Thanks Jake
- bountyhunter
- Thank you received: 337
12 Sep 2010 16:29 #398091
by bountyhunter
Replied by bountyhunter on topic 750 twin head question
I ride a "B", but I have never heard of a "K". What year is it?
- jake100
12 Sep 2010 20:53 #398138
by jake100
Replied by jake100 on topic 750 twin head question
It's a 1983 I guess it is sometimes called a LTD
- Capt America
- Born Bad
- Thank you received: 1
12 Sep 2010 23:14 #398171
by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Replied by Capt America on topic 750 twin head question
I can't say for sure as I've never had to replace a newer head with an older one yet.
I'm going to say I can't foresee any problems at all. You might need the cam cover as well as the top mounting brackets from the other frame, as there is a difference in the bolt spacing on the cam covers where they bolt to the brackets.
I'll take a couple pics tomorrow with my crap camera to show you what I mean.
I'm pretty sure it's only the outside shape of the cam cover that is actually different. So you may even get away with using your cam cover on the older head. If I had one of my other older motors with the cover off I'd try my 83 cover on it for ya.
The only part I've found so far that isn't interchangeable on these motors is the newer permanent magnet rotor onto the 77 motor and probably the 76 as well, due to a different tapper on the crank end.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
