1980 kz650
- ronnie chabot
1980 kz650
11 Sep 2010 17:18
hi
a friends kz650 runs fine starts good .
but for at least 10 min on choke before the two right pipes start to get hot at all.then thay do .
carbs have been cleaned.bike sat for 7 yrs.
take off with choke part way on.then it gets hot and runs ok.
any posts on this one.any help please
thanks ronnie
thanks ronnie
Re: 1980 kz650
11 Sep 2010 19:20
You shouldn't need the choke on for 10 minutes. try turning it all the way off after about 3 minutes or so and see if problem persists. Could be those 2 cylinders are running way too rich with choke on and simply not heating up much. Ed
- Mark Wing
Re: 1980 kz650
11 Sep 2010 19:33
KZ650's are knone for being cold blooded.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Bluemeanie
Re: 1980 kz650
12 Sep 2010 05:27
Make sure the teenie tiny air bleed holes in the carbs are all clear. I also have a 1980 KZ650 and they came from factory with 97.5 or smaller jets so they are lean to begin with. Let us know....
- H1Vindicator
Last edit: 21 Feb 2013 20:46 by H1Vindicator.
- Old Man Rock
Re: 1980 kz650
12 Sep 2010 07:35
1981 KZ650 OEM Service Manual, free download....
jarlef.no/Kawasaki/Series/Z/650/z650files.htm
Pretty much everything you need to learn about carbs, including your set....
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
And no, 10 minutes of choke is not ideal.... Something not right in your carb operations....
Good luck...
OMR
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- DoubleDub
