Bolt problem; 78 KX1000A2
- zeerex99
I looked at the snapped bolts. They appear to be deffective where the breaks happened. Maybe stress cracking? Not sure. They are 32 years old but so are the ones currently in nthe bike.
Any advice? Should I re-use the original bolts? Try to buy new ones? My biggest problem now is getting the snapped off bolts out of a new head. Patience, patience, patience!
- Motor Head
- Thank you received: 391
- zeerex99
- Motor Head
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=395574
There is some discussion on this very issue.
- bountyhunter
- Thank you received: 337
I use about 90 INCH-POUNDS on cam bolts. That's about 7.5 FT-LBS but you must have a low range wrench to get it accurate.So....what torque spec should I use? I've put enough money into this rebuild that I'm not willing to even turn it over, let alone close it up if I'm going to spin cam bearings! Anyone????
- DFIGPZ
- Thank you received: 122
1984 750 Turbo
- Thank you received: 2829
- MFolks
- Thank you received: 540
- Motor Head
www.imperialinc.com/pdf/A_FastenerTorqueCharts.pdf
- Gman
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
- zeerex99
I bought the factory shop manual when I got my ZRX1100 and there's no comparison to the Clymer manual.
