ignition cover question
- inkblot
08 Sep 2010 19:51 #397149
by inkblot
build it, break it, build it better.
ignition cover question was created by inkblot
I have recently aquired a 1980 KZ 650E LTD that needs lots and lots of love. My first of probably many questions is what ignition covers will fit the KZ 650? Is there a reference to what will interchange somewhere? The lower bolt hole was broke off of mine and the top is cracked. This seemed a little too much for the JB welder. haha. Thanks!
- MFolks
- Thank you received: 540
08 Sep 2010 20:18 #397156
by MFolks
Replied by MFolks on topic ignition cover question
I believe if you go to
www.kawasaki.com
and do some digging, it should show a listing on compatable models that share this cover.
Four websites come to mind concerning parts:
1. www.redlinecycle.com
2. www.reproductiondecals.com
3. www.sudco.com
4. www.johnnysvintagemotorcycle.com
3. www.sudco.com
- Thank you received: 2829
09 Sep 2010 07:50 - 09 Sep 2010 07:51 #397241
by 650ed
Replied by 650ed on topic ignition cover question
I don't think you'll find that "fit" is an issue with any of them, but you will find that there are several different patterns. Some have all upper case KAWASAKI, some upper & lower, some have ribbing, etc. You may want to look at the alternator cover on the other side of engine and find an ignition cover with the same pattern. Here are some examples:
Point Covers
Point Covers
Last edit: 09 Sep 2010 07:51 by 650ed.
- inkblot
09 Sep 2010 15:36 #397333
by inkblot
Replied by inkblot on topic ignition cover question
Thanks! Just need one, looks aren't important. She's gonna wind up pretty well bobbed.
- loudhvx
- Thank you received: 1616
09 Sep 2010 15:46 #397335
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic ignition cover question
Even the 550 ignition covers will fit, but will look different.
1981 KZ550 D1 gpz.
Other links.
- JMKZHI
- Thank you received: 48
10 Sep 2010 08:09 #397440
by JMKZHI
Replied by JMKZHI on topic ignition cover question
Also, KZ750-4 engine covers might work. The 650-CSRs & 750Ltd-4s have the same ones.
