78 KZ1000A2 valve cover
- zeerex99
08 Sep 2010 11:09
Any suggestions as to a good sealant (or do I even need it) for the valve cover gasket on this bike? When I took the old one off (factory installed) it didn't seem to have any sealant. Most of my experience is with cars and it's pretty much never used in that application (albeit a different kind of gasket). The majority of cars don't use a sealant for the valve cover(s).
Also looking for mounting recommendations for Dyna-S coils. I'm half tempted to grind off the stock mounting plates and go straight to the frame. One of the old coils was rubbed to the core in the stock position.
Thanks in advance.
Thanks in advance.
- Mcdroid
- Gone Kwackers
Re: 78 KZ1000A2 valve cover
08 Sep 2010 13:05
zeerex99 wrote:
Can't really help you on the Dyna coils...I just attached them to the existing frame mounts. On the valve cover, no sealant is generally necessary, although you might consider sealant around the cam plugs, particularly on the curved side contacting the head.
Thanks in advance.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
08 Sep 2010 17:11
I run a thin bead of the Ultra Black Hi Temp stuff across the rubber cam plugs because they sometimes leak there.
- PLUMMEN
08 Sep 2010 17:24
spray copper coat on it and install
