- Thank you received: 1
what is the valve seat angle of a KZ1100 head?
- martijn
- Thank you received: 797
hold two valves together(one up one down) with the contact faces touching and the stems should run parallel to each other.
hth,
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- martijn
would a 3 angel job seriously improve top end?? I'm using the head on my KZ900 with a big bore 1200cc and 0.395 webcams plus 34 BS carbs. Wondering how much HP it should do. Intake has been ported a little...
- BSKZ650
- Thank you received: 14
also make sure that the valves and guides are WELL oiled during assembly, the vlave is the last place to get oil to it when the bike is first started
77 ltd1000, current rider
76 kz900, just waiting
- otakar
www.flowbenchtech.com/porting/CRH/kz-data.htm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
- Motor Head
- Thank you received: 391
every valve job you do is a 3 angle at the very least you have to cut 3 angles just to place the seat contact area in the right postion and get it the right thicknessusally if your cutting an interfence angle into a seat its 46 degrees that the cutters that readily available from neway. my self personally i set much stock in the interferance cuts not really worth it on the street in my opinion. but you know what they say about opinions,right. the next valve seat cutting set-up i'll be looking getting is probably going to be a serdi they are nice because they made to cut all the angles in one pass.
You might look at the MIRA stuff as well.
www.miratool.ch/?id=42 :)
- timebomb33
- Motor Head
I can say from using them that the Single carbide cutter with all 3 angles on it was the GO! That shop had all the good stuff, and a great Reputation, sorry it was a VW/Porsche shop not Bikes. Sure learned a lot working there though.
