82 750 twin power up grades
- gr8funbikes
07 Sep 2010 21:34 #396951
by gr8funbikes
82 KZ 750 CSR Twin
82 750 twin power up grades was created by gr8funbikes
Im looking to up the horse power on my 82 750 twin. I am thinking about taking it to the drag strip next year. Any help would be great. Can you put bigger cams in it? If so where can I get them? I am thinking about puting a turbo on it. Where can I get 1 and what needs to be done to the motor? Any other tips or tricks would be great. Thanks all.
82 KZ 750 CSR Twin
- bountyhunter
- Thank you received: 337
07 Sep 2010 22:11 - 07 Sep 2010 22:12 #396954
by bountyhunter
Replied by bountyhunter on topic 82 750 twin power up grades
I have a header/can that puts maybe 5 - 10 more HP on my 750 twin in the peak power band at the expense of low end power. It is loud and blocks the oil drain plug so it was a pain to use but it definitely made it wind up faster. I got tired of the hassle and replaced it, so it's sitting in my garage now.
Going with a turbo will cost more than buying a bike that comes with the power you want. And it will also subject the engine to heat and stress it was never designed to handle.
Remember: if there was a cheap and easy way to bolt power on to a given bike, the manufacturers would be doing it.
Last edit: 07 Sep 2010 22:12 by bountyhunter.
- chrispysaki
07 Sep 2010 22:32 - 07 Sep 2010 22:44 #396956
by chrispysaki
Replied by chrispysaki on topic 82 750 twin power up grades
Reduce the weight? High compression pistons? That's my goal for my kz750(4).
Last edit: 07 Sep 2010 22:44 by chrispysaki.
- martijn
- Thank you received: 1
07 Sep 2010 23:06 #396960
by martijn
Replied by martijn on topic 82 750 twin power up grades
see the KZ400 forum, 750 engine section. I did write some interesting stuff there (cheap big bore and turbo)
- DoubleDub
- Visitor
08 Sep 2010 07:18 #397007
by DoubleDub
Replied by DoubleDub on topic 82 750 twin power up grades
There was mention somewhere recently of some really lumpy cams for the 750 twin, not sure if they are still being made, though. Probably great for drag racing.
- martijn
10 Sep 2010 00:40 #397400
by martijn
See some turbo and big bore details
www.armbell.com/forum/viewtopic.php?t=12...t=turbo&mforum=kz400
and www.armbell.com/forum/viewtopic.php?t=92...t=turbo&mforum=kz400
