- Thank you received: 16
OFF SET SPROKETS
- JEFFG1
07 Sep 2010 17:07 #396862
by JEFFG1
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
OFF SET SPROKETS was created by JEFFG1
hi all as some of you know i have a winter project i am getting ready to start but in the meantime i am riding it and dont want to tear it apart to do any measurments.here is what is going on it is a 76 900 i have a extended swingarm @ i am putting a 190 tire on a 6" gsxr wheel. the question is the offset of the frt. sproket??? i heard that 3/8 offset is the most you can go without frame problems if that is true is that going to be enough to work with this setup??any help would be great i would like to get the sproket order so come winter i am ready to go thanks for your help
- timebomb33
- Thank you received: 10
07 Sep 2010 17:20 #396868
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic OFF SET SPROKETS
with that size of wheel your probably going to have to use a 5/8" sprocket which means your going to need to relieve the frame some right in the area the chain runs top and bottom. even with 530 chain. i know i had to myself at least.
- JEFFG1
07 Sep 2010 17:23 #396869
by JEFFG1
Replied by JEFFG1 on topic OFF SET SPROKETS
how did that work out ?? did you have to go deep?
- timebomb33
07 Sep 2010 17:29 #396871
by timebomb33
no i only had to flatten out the inner part of the tubes by about a 1/2" to get enough clearance i was i a rush so all i did was heat up the area with a set of torches and crushed it with a big c clamp just in the areas that needed it and it didn't even distort the front of the tube just take your time and don't go crazy with the heat. this was on my drag bike so i didn't have a fancy high doller paint job to worry about. if your taking it right down anyway you might want to notch it and then fill it back in nice but i was in a rush and was racing it that weekend so i had to do it fast and dirty.
- Old Man Rock
- Thank you received: 225
07 Sep 2010 17:50 #396882
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic OFF SET SPROKETS
12.5mm (~ 1/2") offset on mine no problems... It's close but with proper chain slack 1" to 1 1/4" I've had zero problems and I run a 180 tire on the rear....
Chain to tire clearance is no problem, way then more enough clearance... Frame is another story....
From others projects, 5/8" meant as mentioned, frame fabb work is required or offset the rear tire :pinch: an 1/8th inch....
Just in case... German machined extremely well made (one piece) CC sprockets in both 530 and 630 pitches....
americanclassix.com/streetfighter_conversions.html
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
07 Sep 2010 19:17 #396903
by timebomb33
dave is your wheel 6" wide or 5.5"
- Old Man Rock
08 Sep 2010 02:39 - 08 Sep 2010 02:45 #396966
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
5.5" Rim width on the back...
The last time I was over at the website, the offsets are now 12mm versus 12.5mm... Unlike our wives :pinch: :whistle:, that additional .5mm makes a difference...
I could see where a 6" rim would cause some serious modifications... If I remember correctly (yeah right :blush: :laugh:) Mark1122 had to have his rear hub milled down for it...
As much as I love my KZ, I'll tell ya, that rear swingarm conversion (math, geometries, angles, measurements, alignments, modifications etc...) really messes with the brain.... :S :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 08 Sep 2010 02:45 by Old Man Rock.
- JEFFG1
08 Sep 2010 04:46 #396979
by JEFFG1
I THINK I SHOULD WAIT TILL WINTER PULL THE COVER AND DO SOME MEASURING I AM GETTING ALITTLE MESSED UP NOW GETTING TO MANY SIZES . I MOCKED IT UP ON THE BIKE A FEW WEEKS AGO THE CHAIN CLEARED THE TIRE AND FRAME BUT I AM SURE THE CHAIN WASNT TRACKING RITE
- timebomb33
08 Sep 2010 06:57 #396999
by timebomb33
i use a widened gsxr wheel that is actually 6" inside lip to inside lip i use a 5/8 sprocket with an irishwill made bearing support oh by the way you might want to look at going with a bearing support as well.with my swing arm setup i even had to offset the wheel to the right a bit. so it would clear properly.
- Thank you received: 797
08 Sep 2010 07:07 #397002
by 531blackbanshee
Replied by 531blackbanshee on topic OFF SET SPROKETS
is the wheel centered up in the swingarm now?
does the centerline of the tire and the centerline of pivot tube line up?
when i built my swingarm i centered my hub,and the rim was offset 3/8's to the right.i was able to get away with a 3/8's offset sprocket.i would definately check it myself before i spent any money.
a few moments with a string and a ruler could save you time and money.
- JEFFG1
08 Sep 2010 11:07 #397037
by JEFFG1
i think i will wait till winter which is very close to order so i can get out the tape & see what is up this is why i like this site everyone is ready to help out could not ask for more thanks alot
- mark1122
- Keep twisting it
- Thank you received: 109
10 Sep 2010 09:45 #397461
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic OFF SET SPROKETS
i had to do the same thing timebomb33 did. heat and flatten the inner frame, and use a 5/8" offset. then i milled my hub to get the chin loser to the tire. ended up with a 170 tire on a 5.5 zrx12 rim and arm.i run it on a rd race track with the rear rim offset from center of the front rim, and its fine.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
