- Thank you received: 13
83 LTD440 Camchain Tensioner(how does it work?)
- Sandy
- Fly High,Tony
06 Sep 2010 17:18 - 06 Sep 2010 17:28 #396609
by Sandy
1977 KZ1000 A-1
83 LTD440 Camchain Tensioner(how does it work?) was created by Sandy
I have it off the engine and I'm sitting here trying to figure out how it works.There are 2 springs,and a screw on the outside of the housing,right on the end.That screw threads into(and through)the housing AND into the end of the shaft,locking the shaft into place.
There's a tapered collar that a bearing seats into.
I don't see how to make an adjustment though.:huh:
1977 KZ1000 A-1
Last edit: 06 Sep 2010 17:28 by Sandy.
- Sandy
- Fly High,Tony
06 Sep 2010 18:25 #396623
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic 83 LTD440 Camchain Tensioner(how does it work?)
Hmm...my guess is that it's NOT adjustable,only keeps spring tension on the chain.
Either way,it's back on the bike.
1977 KZ1000 A-1
- PLUMMEN
- Thank you received: 104
06 Sep 2010 19:48 #396649
by PLUMMEN
Replied by PLUMMEN on topic 83 LTD440 Camchain Tensioner(how does it work?)
thats how we used to convert the auto adjusters to manual,a long bolt and stop nut to lock in place
- Capt America
- Born Bad
07 Sep 2010 10:52 #396780
by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Replied by Capt America on topic 83 LTD440 Camchain Tensioner(how does it work?)
It's an automatic tensioner, user input not required. All you can do is inspect the push rod, sleeve and lock ball for dents/damage, and measure the spring free length. Hopefully you replaced it properly, you can screw things up if you reinstall it improperly.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
