glowing #3 exhaust header tube
- zx12ryder
06 Sep 2010 09:57 #396491
by zx12ryder
You cant take it with you so enjoy it while you got it!
glowing #3 exhaust header tube was created by zx12ryder
A friend of mine has a 83 KZ650 CSR. He just got a new after market exhaust after the originals rusted out. He says when he starts the bike the #3 header pipe glows. Too rich?..too lean? what may cause this. As for the carbs we have both agreed they need to been cleaned out thoroughly since it has not been done. Any info would be greatly appreciated.
- bountyhunter
- Thank you received: 337
06 Sep 2010 11:24 #396518
by bountyhunter
Replied by bountyhunter on topic glowing #3 exhaust header tube
Sounds like it is too lean.
- Polar_Bus
- Thank you received: 7
08 Sep 2010 05:13 #396982
by Polar_Bus
Bikes:
'84 GPz1100
'06 HD Fatboy
Replied by Polar_Bus on topic glowing #3 exhaust header tube
bountyhunter wrote:
+1, sounds like you have a debris clogged #3 carb.
Bikes:
'84 GPz1100
'06 HD Fatboy
- timebomb33
- Thank you received: 10
08 Sep 2010 06:50 #396998
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic glowing #3 exhaust header tube
ditto x 3
- TeK9iNe
- What did you do!?!
- Thank you received: 28
08 Sep 2010 07:08 #397003
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic glowing #3 exhaust header tube
You should do a compression check on the engine and get some baseline numbers to ensure still good operating components.
It takes some serious lean-ness to make the header pipe glow, and this can spell trouble for alot of other components.
When cleaning the carbs, blow carb cleaner spray through all the jets and passageways while visually verifying the spray coming out the jets/ports in the carb with a nice clean powerful flow. Ideally when finished, the spray should look the same through all passages/carbs.
You should be able to hold the jets up to a light and actuall see the cleanly defined taper inside, even in pilot jets, unless your eyes are bad. Then they're clean.
Make sure carb-engine holders are bonded/airtight firmly in place with some Permatex Motoseal or #2 gasket maker, as they are impervious to gasoline.
Best of luck.
Best of luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
