I need parts!!
- JensGT500
I own a KZ 750E3 or E2 dont know really.
But it has this "ticking" noise.
It's most likely the hydraulic valvelifters but I'm not 100% sure.
No the main problem is'nt finding out what is wrong (I have a good friend whos a mechanic!)
But WHERE do I find the parts necessary:dry:
Valvelifters/ all bearings etc. etc...??
I've looked trough numerous sites and all I can find is the valves themselfes.
Hope you can guide me in the righty direction!
And pardon my french if I've spealed wrongly somewere
:laugh:
By the way I live in Denmark so it would be nice if there were a supplier in Europe.
Thanks in advance /Jens
- jbw7300
- you can't ride if your fried
Post edited by: jbw7300, at: 2006/04/15 06:34
84 kz 700 a1 sports
- steell
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- u.k. Dave
- Thank you received: 5
- JensGT500
There are no vallve lifters in a KZ750E, it has valves, valve spring seats, inner and outer valve springs, valve spring retainers, half moon clips (to hold the retainers on the valve, shims (to adjust clearance) on top the valves, buckets (that go over the top of the shims, retainers, and springs) and the cams ride on top of the buckets and push them down directly (thus opening the valves). The link in the previous post will take you to the place where you can find the illustrated parts pages and see for yourself.
:silly: I now know!
We mesuared the valveclearence to between 0.00 (!!!!) to 0.08mm.
According to the books (haynes)it should be around 0.08 to 0.18.... How can this be?
My mechanic measured it by the book and everything.
Haynes sugest that a smaller shim should be inserted and on it again...:blink:
It could only be that it have been adjusted before very poorly, so that the clearence on valve 4 and 8 in this case i 0.00 right??
I am SO sick of this!
:S
- steell
- JensGT500
Don't it get BIGGER?
Could someone please make an:
"what to do now...-in 1.blabla 2.blabla"
That would be highly apreciated:)
By the way the haynes manuel says this:
1. Turn the crankshaft so the "T mark" lines up with the fixed line on the block.
2. Then measure the clearence noting that the "lube" should point away from the valve.
3. Turn the crank as nessesary for checking all valves.
? Whats the deal with lining the marks, when you have to turn the crank 10 times to get all lubes poiting away from the valve anyway?
Again pardon my french;)
- JensGT500
- wiredgeorge
