- Thank you received: 28
Lash continues to increase...?
- TeK9iNe
- What did you do!?!
Whats the deal? We've checked compression/leak and quench/heights, bolt torques. Pulled head inspected seats and valves and guides. cams are true and bearings good, no increases in spec. Everything nice an clean and runs great, just gets louder till we replace shims...???
Myself and a couple other mechanics are lost on this one. Maybe we're just tired here, but I seriuosly cant find the reason for it.
Any suggestion???
Thanks.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
What was done to the head?
Valve job, new/old valves, new guides, new springs, retainers etc... or using 30 year old originals....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
- mark1122
- Keep twisting it
- Thank you received: 109
Not knowing the model we cant be specific.
As u know, usually the face and seats ware and the clearance shrinks.
Could the stems be getting shorter through ware?
or the shim or rocker?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- PLUMMEN
- Thank you received: 104
- APE Jay
- Banned
- Thank you received: 58
- Kraz1
Keepers
- PLUMMEN
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- Jeff.Saunders
...but all the aftermarket valves are radius keeper grooves.
Not true at all. There are several companies making the earlier Z1 style valves. We stock 2 different brands.
www.z1enterprises.com/SearchResult.aspx?...&KeyWords=z1%20valve
www.z1enterprises.com/detail.aspx?ID=321
As to the valve clearances INCREASING.
I've only seen this with engines burning oil - the valves/seats get a layer of carbon on them.
The only other thought is whether the clearances were checked with the engine cold both times. There is a fair variance in clearance depending on engine temperature. On one of my engines, I checked the clearances hot, then again multiple times as the engine gradually cooled down. The clearances changed several thou during the cooldown.
Z1 Ent on Facebook,
- larrycavan
- Visitor
As said, the valve lash on a clients machine continues to increase and every couple months in to a season he comes in and sure enough we've had to use larger shims on more than one of the valves.
Any suggestion???
Thanks.
What engine is this ?
What is the mileage between visits?
How is the bike ridden?
As someone pointed out, it sounds like a retainer issue.
