- Thank you received: 25
Kz750 Cylinders - How big can you go?
- T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- DFIGPZ
- Thank you received: 122
1984 750 Turbo
- DoubleDub
- Visitor
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- DFIGPZ
T dub i have a set of 4 750 turbo connecting rods email me direct at b.flood@myactv.net if interested.Sounds like these rods wont work. 4mm longer is a huge difference. I'd say we keep trying to find GPz750 turbo rods or we could investigate the carillo option.
Edit: I just emailed carillo, hopefully they'll get back to me. For the price of this build I'd be willing to buy aftermarket rods if they weren't crazy expensive.
PS - I've been investigating turbos all day, I think a GT20 would be the best bet for a 810cc engine running moderate to high boost. Lorcan runs a GT22 I believe, so for a street bike a GT20 or even a GT15 would be good I think.
1984 750 Turbo
- DoubleDub
- Visitor
I've been looking around, and Mr. Turbo sells an external electric little small scavenge pump. I'll run this or something similar, and look out for GPz rods on ebay. I wont be starting the build for a year or two so I can afford to wait.
My build is on roughly the same timeline, maybe a little further out as the wife is trying to go back to school. I'm just trying to get some ideas/parts put together to keep interest going.
So, what have we decided is the max size piston that can be put in with new sleeves? I saw a CC size, but no mention of the piston size.
Also, I believe it was Steell that said the Gpz rods would work even though they were 4mm longer, but I'm assuming they would make a big difference in static compression in the wrong direction for a forced induction engine.
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- APE Jay
- Banned
- Thank you received: 58
We get $1295 for custom Carrillos. See what they tell you then get back with us.
Jay
- APE Jay
- Banned
you could use a spacer under the base gasket that would eat up the 4mm difference and if you are going to use a turbo you could even go to like 6mm to drop the compression...
Probably couldn't find a cam chain for that
- PLUMMEN
- Thank you received: 104
or just have pistons made with the correct wrist pin heightyou could use a spacer under the base gasket that would eat up the 4mm difference and if you are going to use a turbo you could even go to like 6mm to drop the compression...
- DFIGPZ
1984 750 Turbo
- APE Jay
- Banned
He is talking 4 mm. Move the pin up 4 mm and it would be in the rings, and so close to the dome on the bottom that the rod might not fit.
