- Thank you received: 99
6 speed in GPz 750 questions
- koolaid_kid
I have cracked the cases and examined the gear shafts. I have slipped the 6 speed output shaft into the case. It appears to be an exact fit, which pleasantly suprised me.
My questions:
Has anyone else done this or seen it done?
Are there any things I need to be aware of?
It appears that the sprocket will have the same alignment with the rear sprocket as the 5 speed I am removing. Is this correct?
I have noticed that at least 2 of the gears are not as wide as the 5 speed. Will I have any problems with the power of the 750, which will have a Wiseco 810 kit, shaved head, K&N pods, and a V&H 4-1 header?
Thanks in advance, kk
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- RollingStock
Post edited by: rollingstock, at: 2005/10/24 22:08
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- inline4
- Thank you received: 1
I can't answer your questions, but I AM looking forward to your results. I have a 2001 ZR-7S (GPZ750-type engine) and heard that I could replace my 5-speed tranny with that of a GPZ550.
Good luck, and keep us posted on the outcome.
Jim
- apeman
- Thank you received: 3
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- koolaid_kid
I did check the gear ratios, they are as follows:
550
1st 2.57
2nd 1.78
3rd 1.38
4th 1.13
5th 0.96
6th 0.85
750
1st 2.33
2nd 1.63
3rd 1.27
4th 1.04
5th 0.88
It has a lower first gear, kind of mixed in the middle gears, and a slightly higher 6th gear. The overall spread is wider, but geared to the lesser power of a 550.
Since the bike will primarily a canyon carver, this is ideal for me. When chain replacement time comes, I will probably play with the sprocket ratios a bit to make it more ideal for the added power of a 750.
1983 GPz 750
- apeman
- koolaid_kid
I will have to wait until it is running to determine what to do about the slightly wider spread and lower first gear; I really do not want nor need a wheelie machine.
I would love to move to a 530 set when I change the chain, but I have been told that the offset of the countershaft sprocket is a problem with the 750 engines (at least on my GPz). Would you know of a solution to this issue?
1983 GPz 750
- steell
But that will be next spring when I build an addition onto my garage
- koolaid_kid
Maybe as soon as I get my lathe and mill installed we'll have a solution
Woohoo!! :laugh:
I mean, dang!! :blink:
That's O.K., the GPz will take that long to get going.
I hope to have an initial answer to the forum by this time next week. I will fit both shafts, forks, and drum and check it out on the bench. Since the kickstarter is a non-issue, I feel pretty good about my chances.
I will also be posting a related issue over in the bodywork forum...
1983 GPz 750
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
I can e-mail you a gear chart you can play with for your sprocket choice. I can't post a link here.
Post edited by: CoreyClough, at: 2005/10/25 21:57
'85 GPz550(ZX550-A2)
- koolaid_kid
thanks, kk
Post edited by: koolaid_kid, at: 2005/10/26 17:55
1983 GPz 750
- mariozappa
Man!
You're gonna have to tell me where you ride in Indiana!
1977 KZ650C1
and the KZ650/KZ750 Conversion
