air in cylinder to keep valve closed...true?
03 Sep 2010 10:25 #395846 by apbling
I buddy of mine told me he plans on taking the valve seals out of his head. Ok, but then he tells me he's going to put air in the cylinder to keep the valve closed and complete the job with the head on... this seems like it wouldn't work... anyone heard of this or tried this?
03 Sep 2010 10:44 #395849 by Kidkawie
Replied by Kidkawie on topic air in cylinder to keep valve closed...true?
Yes. You have to bring that cylinder up to TDC and lock the crank. The air pressure can rotate the engine and allow the vale to drop into the combustion chamber.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
03 Sep 2010 11:34 #395858 by bountyhunter
Replied by bountyhunter on topic air in cylinder to keep valve closed...true?
Somebody posted that they use a segment of cloth rope pushed in through the spark plug hole which could be pulled out later. Piston comes up and squeezes it into the valve.
  • testarossa
03 Sep 2010 11:55 #395864 by testarossa
Replied by testarossa on topic air in cylinder to keep valve closed...true?
I have used both methods, and they both work fine.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • TeK9iNe
  • What did you do!?!
03 Sep 2010 12:15 #395869 by TeK9iNe
Replied by TeK9iNe on topic air in cylinder to keep valve closed...true?
I've never bothered doing any headwork without taking it off so i am pretty curious about... how do you re-compress the valve springs to get the keepers back in during install?
I know how to get them off fine, but back in...???
Is there really a tool for this?
The air and rope methods work fine, I've even heard of guys just dropping a balloon into the cylinder then blowing that up and tying it. When your done, just pop it and pull out.
Good Luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
03 Sep 2010 12:20 #395870 by Jack
We've used the compressed air through an old modded spark plug to change valve springs and seals without removing the head. Jerry rigged a tire iron and the cap portion a valve spring compressor to depress springs and put the keepers on the stem.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
03 Sep 2010 15:59 #395899 by 650ed
I've done the air thing on my Chevy truck (350 V8) when replacing valve seals. I didn't worry about TDC, I just used lots of air - no problem. Bike still has originals with no leakage. Ed
  • TeK9iNe
03 Sep 2010 19:48 #395940 by TeK9iNe
:laugh: Nice.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • larrycavan
  • Visitor
03 Sep 2010 19:57 #395943 by larrycavan
Replied by larrycavan on topic air in cylinder to keep valve closed...true?
Something to consider....
If the seals are shot, the valves are usually coked up pretty badly. On old bronze guide heads, the guides are most always shot.....
Before going to all that trouble do this first.
Pull the spark plugs out. Turn the motor over and looking through the plug hole, have a good look at the seating face of the valves and look for heavy carbon build up.
Sometimes the intakes will be seating well enough but the exhausts will almost always be in need of refacing and seats cut.....
  • testarossa
03 Sep 2010 20:11 #395951 by testarossa
Larry makes a good point. If the valves don't seal, then the air trick don't work. The rope would work, but if the valves aren't sealing then you are wasting your time since the head needs to be rebuilt.
2004 ZX-10R
Angola, IN
04 Sep 2010 06:53 #396019 by Jack
Good point Larry. Neglected to mention that this was not a street bike motor and the real mission was to replace springs not the seals.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
05 Sep 2010 15:04 #396318 by sparkn
TeK9iNe wrote:
I've never bothered doing any headwork without taking it off so i am pretty curious about... how do you re-compress the valve springs to get the keepers back in during install?)
I use a valve spring compressor that looks similar to a gear puller (tricky to use and not incredibly safe). I've seen safer ones that attach to the rocker studs/camshaft rails that have a lever that compresses the spring like a camshaft lobe would. I would prefer that style if I could find one for my bike.
1979 KZ650 SR
