- Thank you received: 58
Anyone have access to a stock Z2 piston?
- APE Jay
- Banned
- Motor Head
- Thank you received: 391
02 Sep 2010 13:10 #395649
by Motor Head
Replied by Motor Head on topic Anyone have access to a stock Z2 piston?
No eBay APP ID and/or Cert ID defined in Kunena configurationI had a look at the parts diagrams, didn't see it listed for a part #? Do you know the Kaw Part #?
Here is a piston on Ebay.
110401530356
110401530356
- otakar
02 Sep 2010 13:19 - 02 Sep 2010 13:22 #395652
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Anyone have access to a stock Z2 piston?
I believe that that one is for the twin and not the Z2. The Z2 had a 58mm stroke and a 64mm bore. This will be a bit hard to find in the US. You might have to go to So. Africa, Australia, or J-pan to get that. I would go up to the stock OE KZ900 pistons of 66mm. That will bring you up to 793cc and because of the overbore it will also raise your red line quite a bit.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 02 Sep 2010 13:22 by otakar.
- Motor Head
02 Sep 2010 13:25 #395654
by Motor Head
Found a good read for the model on this site, says they also went by "RS" "Road Sport"
750rs.webs.com/z2.htm
- otakar
02 Sep 2010 13:28 - 02 Sep 2010 13:34 #395655
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is one that is .020 over, if you want to have it cut down. 13001-063 is the stock size part #
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 02 Sep 2010 13:34 by otakar.
- Motor Head
02 Sep 2010 14:01 #395661
by Motor Head
Here is a page with the Z2 parts diagram:
translate.google.com/translate?hl=en&sl=...ficial%26channel%3Ds
- APE Jay
- Banned
02 Sep 2010 14:28 #395667
by APE Jay
Replied by APE Jay on topic Anyone have access to a stock Z2 piston?
I am just trying to verify that theyt were exactly the same as a Z1, only 2 mm smaller.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
02 Sep 2010 14:51 - 02 Sep 2010 14:52 #395673
by kzz1p
Replied by kzz1p on topic Anyone have access to a stock Z2 piston?
sorry!
Last edit: 02 Sep 2010 14:52 by kzz1p.
- otakar
02 Sep 2010 14:57 #395674
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Yes they were 2mm smaller.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- APE Jay
- Banned
02 Sep 2010 15:42 #395688
by APE Jay
Yes, but same pin, deck height, valve pockets?
