anyone have an inlet cam sprocket handy to photgra
- oldster
01 Sep 2010 09:18 #395377
by oldster
anyone have an inlet cam sprocket handy to photgra was created by oldster
can anyone please help with a photo of a z900/1000 32 tooth inlet cam sprocket,the rubber side buffers on mine have disintergrated so bad i don't have the 28th pin mark,i have the small arrow in the steel for lining up with the top split line but need a pic to determine the 28 pin position,any help would be brilliant , oldster
- moneypit
- Thank you received: 35
01 Sep 2010 13:15 #395432
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic anyone have an inlet cam sprocket handy to photgra
We'll see if this helps. I'll try and get some more pics if it doesnt. There isnt a line up arrow on the intake cam I dont think? So you may have to count teeth back from the bolt hole.
2-76 kz900
St Paul MN
- oldster
01 Sep 2010 13:23 #395433
by oldster
Replied by oldster on topic anyone have an inlet cam sprocket handy to photgra
thanks for that moneypit,i do need the whole camwheel in the pic though,there should be a tiny arrow punched into the steel of the wheel that aligns with the splitline that camcover bolts to,i need this to get number of teeth to the 28 mark, cheers oldster
- moneypit
01 Sep 2010 13:50 #395441
by moneypit
2-76 kz900
St Paul MN
2-76 kz900
St Paul MN
- oldster
01 Sep 2010 14:03 #395444
by oldster
god bless you moneypit,just what i needed,all the best oldster
