- Thank you received: 15
KZ1000 burning oil all the sudden
- madmatt1
1977 KZ1000 LTD
1977 KZ1000A
- bountyhunter
- Thank you received: 337
With those symptoms, I would guess rings. Maybe an oil ring stuck or collapsed?Then a riding friend mentioned that there was a brief plume of white smoke when I cracked her open to spank his Harley.
The most noticeable is when you get on the throttle aggresively, and when you downshift/stop quickly. The other day I had to stop quick at a light, and literally had a cloud of smoke catch up with me when I stopped,
Is the compression good?
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Nelson
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- BSKZ650
- Thank you received: 14
you prob have oil on one or more plugs so a good look at them will also clue you in.
dont recall you sayin how many miles are on the bike and if any engine work had been done to it before
77 ltd1000, current rider
76 kz900, just waiting
- madmatt1
1977 KZ1000 LTD
1977 KZ1000A
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I'm just waiting for my friend to get a chance to bring his fancy leakdown tester over to my house. I've pulled the plugs, none of them are wet, but they are sooty, as the bike has been running rich. By the way, it has 25,000 miles, and I have no clue if it has ever been rebuilt. My best guess would be no, it hasn't. I know this is just part of having a motorcycle, but I am pretty much beyond frustrated at this point. I love these bikes and always have, but owning this one has been a love/hate relationship if you know what I mean. I just don't know whether or not I want to spend more money to rebuild it, or just throw in the cards and buy something else.
Throwing in "the carbs" :laugh: , and buying something else will be a whole lotta change for a "most likely", fairly easy to fix problem that wont really cost that much. + You'll just be getting another bike, in other words - another bag of headaches.
Leakdown/compression tester will not show any difference if it is just an oil control ring... sometimes is best to just use a bright light and look through the plug hole/intake/exhaust for damage/wear, or tear it right down.
Takes me about 3-4 hrs to casually rebuild the top end on a KZ, you should be able to do everything as a newb in a weekend (tools permitting). If your a newb... :silly:
GL!
PS! There's lots of short cuts to save $ without cutting quality. Keep askin, we'll let you know
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- hocbj23
- Visitor
- madmatt1
I'm pretty comfortable doing just about anything ASIDE from rebuilding an engine. Haven't been down that road yet. I've read that if you check the compression and have cylinder(s) that's low, and then you pour a teaspoon of oil in it and turn it over again and get higher compression, it's the rings. Does this usually work well? I just want to get the best idea of what's going on before I tear into it. I'll be honest, I'm not mentally prepared to dig into the bottom end yet...
1977 KZ1000 LTD
1977 KZ1000A
- BSKZ650
too much pressure can cause it to smoke.
- madmatt1
1977 KZ1000 LTD
1977 KZ1000A
- TeK9iNe
Good Luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
