Yoshimura cam #103-01
- Oldz1guy
- Still Crazy After All These Years
29 Aug 2010 19:17 #394886
by Oldz1guy
Yoshimura cam #103-01 was created by Oldz1guy
Hi Everyone
Just wondering if anyone has ever heard of Yosh cam #103-01 for the z1's? Lift is supposedly .145 Intake and .120 Exhaust.
Thanks in Advance
Brad
Thanks in Advance
Brad
- PLUMMEN
- Thank you received: 104
29 Aug 2010 19:55 #394899
by PLUMMEN
Replied by PLUMMEN on topic Yoshimura cam #103-01
motor wouldnt run with those lift numbers! :laugh:
- otakar
29 Aug 2010 20:10 - 29 Aug 2010 20:22 #394903
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Yoshimura cam #103-01
PLUMMEN wrote:
Oh it would run alright! You could pull tree stumps with it, Literally! That motor would be for a tractor, not a motorcycle. :laugh: :woohoo: I think he might mean .345 and .320 this would be close to a Z3 cam setup. Yoshimura was one of the few cam makers that did not use identical cam lifts for both intake and exhaust. I have a set of Yoshi Bonneville cams that are .380/.360 respectively. This leads to a very torquie motor. This is why on my GPz1150 I chose to go with .420/.410 setup. It works grate.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Aug 2010 20:22 by otakar.
- Oldz1guy
30 Aug 2010 19:06 #395120
by Oldz1guy
Replied by Oldz1guy on topic Yoshimura cam #103-01
On the cam shaft close to the cam sprockets both cams have a #2 on them. Also on the ends of the cam there is a B on both. Any idea????????????
Brad
Brad
- otakar
31 Aug 2010 04:53 #395168
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
It has been a long time since I looked at my cams in the Z1R. Pictures would help.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
31 Aug 2010 06:11 #395179
by larrycavan
Replied by larrycavan on topic Yoshimura cam #103-01
Oldz1guy wrote:
Measure them. Measure the height of the entire lobe from the bottom of the base circle to center of the lobe tip.
Turn it sideways and measure only the base circle. It's probably 1.110"
Then subtract the base circle from the first measurement. That is the lift.
Hi Everyone
Thanks in Advance
Brad
