- Thank you received: 12
head nut washers
- lewisj
28 Aug 2010 20:05 #394639
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
head nut washers was created by lewisj
Does anyone sell the copper head nut washers. I am installing APE heavy duty studs and nuts. Just thought I would replace the washers too.
Thanks Jim
Thanks Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- PLUMMEN
- Thank you received: 104
28 Aug 2010 20:16 #394642
by PLUMMEN
Replied by PLUMMEN on topic head nut washers
heat them up cherry red with a propane and toss in a bucket of water to cool them off,good as new
- lewisj
28 Aug 2010 20:45 #394646
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Replied by lewisj on topic head nut washers
Plummen, I like your way of thinking!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- PLUMMEN
29 Aug 2010 05:46 #394702
by PLUMMEN
works on copper head gaskets also,and banjo bolt washers for brakes as long as they arent plated
