- Thank you received: 2098
1075cc head gasket question???
...will be running 10.5:1 compression. Sounds like the 2 piece gasket is the popular opinion so I will go with it. Do you use silicone AND the o-ring in the center groove or just one/ Also, do you use any Yamabond 4 or Sealant with the composite (Cometic)gasket?....
Per FSM, just the o-ring and no sealant.
[Click on image to enlarge view.]
- larrycavan
- Visitor
LarryC,
I will be running 10.5:1 compression. Sounds like the 2 piece gasket is the popular opinion so I will go with it. Do you use silicone AND the o-ring in the center groove or just one/ Also, do you use any Yamabond 4 or Sealant with the composite (Cometic)gasket? Thanks Larry , Your expertise is greatly appreciated!
Jim
Jim,
Use either the O ring or silicone for the cam chain tunnel with 2 piece gaskets.
I would use some case sealer around the outside stud holes where the oil comes up to the head. In fact, I'd run a dab right around the outside edge of the gasket, all the way around.
If you have the money, get the head surfaced, just enough to make it straight. Generally takes .005 - .008".
Don't try to remove all of the triangle shape divot that the head gaskets often cause. Just make the head flat.
Re-torque the head nuts after you heat cycle the motor one time. Make sure it's stone cold for that.
Check them again in 100 miles.
It really helps to fight off oil leaks
Larry C
- taildragger1197
- Thank you received: 17
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
- Tony
- Thank you received: 13
- lewisj
- Thank you received: 12
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
- Tony
- larrycavan
- Visitor
- lewisj
Thanks Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- Tony
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Old Man Rock
- Thank you received: 225
C8017 Gasket, Head, 1075cc thru 1170cc (75mm, 1 piece), CFM-20, KZ900-1000 - Cometic $34.59
www.schnitzracingstore.com/catalogs/cata...93304&showprevnext=1
Dynoman has them as well....
#C8018 Head Gasket
72mm -- 1-piece -- CFM-20 -- 1075cc
$49.95
dynoman.net/engine/gaskets-cometic.html
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
