1075cc head gasket question???
28 Aug 2010 09:15 #394522 by lewisj
1075cc head gasket question??? was created by lewisj
I am assembling the head gasket on a rebuild 1075 z1. I have a 1 piece copper gasket and also a 2 piece paper gasket with the center o-ring. Is one better than the other? If I do use the 1 piece copper gasket, can I still use the o-ring or just fill the groove with hi temp sealant? Thanks for the help!!
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
28 Aug 2010 09:24 #394524 by PLUMMEN
Replied by PLUMMEN on topic 1075cc head gasket question???
use the 2 piece gasket,copper gasket requires each cylinder to be o ringed to seal oil leaks
28 Aug 2010 10:13 - 28 Aug 2010 10:15 #394532 by APE Jay
Replied by APE Jay on topic 1075cc head gasket question???
You talking about the o'rings in the top of the sleeves?
Last edit: 28 Aug 2010 10:15 by APE Jay.
28 Aug 2010 10:37 #394539 by PLUMMEN
yep,thats my experiance anyway.copper gasket will not seal without cylinders being o ringed B)
28 Aug 2010 11:11 #394549 by lewisj
Replied by lewisj on topic 1075cc head gasket question???
I have installed o-rings in the cylinder sleeves that fit into the cases. Are there o-rings that fit between the cylinders and the head?
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
28 Aug 2010 11:13 #394550 by lewisj
One other thing for now, do you use any gasket sealants or yamabond 4 with the 2 piece head gasket? Thanks Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
28 Aug 2010 11:59 #394555 by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
28 Aug 2010 12:22 #394558 by PLUMMEN
install head gasket dry,fill the the groove where the o ring in center goes with silicone B)
28 Aug 2010 12:33 #394559 by lewisj
Thanks Plummen, sounds like a plan!
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
28 Aug 2010 21:55 - 28 Aug 2010 21:57 #394678 by APE Jay
Have encountered thr oposite too. The o'rings in the sleeves are to control cylinder pressure. However, we have seen cases where the gasket is not soft enough and not using good studs, has caused the o'rings to hold the gasket up off the block, which lets oil pour out everywhere.
Getting copper gaskets to not leak oil is a challenge.
Spraying them with Copper Coat several times, allowing it to get tacky dry between c oats, seams to work best.
Last edit: 28 Aug 2010 21:57 by APE Jay.
  • larrycavan
  • Visitor
29 Aug 2010 06:40 - 29 Aug 2010 06:55 #394707 by larrycavan
Replied by larrycavan on topic 1075cc head gasket question???
Unless you have to run racing compression, go with a composite head gasket.
I like this on copper gaskets
Last edit: 29 Aug 2010 06:55 by larrycavan.
29 Aug 2010 08:20 #394759 by lewisj
LarryC,
I will be running 10.5:1 compression. Sounds like the 2 piece gasket is the popular opinion so I will go with it. Do you use silicone AND the o-ring in the center groove or just one/ Also, do you use any Yamabond 4 or Sealant with the composite (Cometic)gasket? Thanks Larry , Your expertise is greatly appreciated!
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
