1981 KZ CSR 650 H1 cam questions.
27 Aug 2010 18:28 #394390 by Emberblade
1981 KZ CSR 650 H1 cam questions. was created by Emberblade
hello. i have a stupid question... how do you reinstall the cams on the kz? i know how to physically put them on, but i'm clueless as far as the timing and position relative to the cam chain and pistons go.
what i do know:
1. the 1st and 4th pistons must be at TDC.
2. the cam has to be postitioned in such a way that it aligns a mark with the side of the engine.
3. the marks on my cam read: "Z6EX" "Z7EX" and "EX"
other than that, i have no idea about what to do or how to align them. i think that the cams might have been replaced by the previous owner with aftermarket ones, not sure, but my haynes manual says that they should be marked with a "T"
any help would be appreciated, i just finished rebuilding the engine, and would hate to blow it all just because of a stupid cam mistake that i know i can avoid.
1982 KZ1000J ELR Clone
27 Aug 2010 18:31 #394392 by 650ed
Replied by 650ed on topic 1981 KZ CSR 650 H1 cam questions.
You rebuilt the engine without a manual? What did you use for a reference? Ed
27 Aug 2010 22:15 #394469 by Emberblade
Replied by Emberblade on topic 1981 KZ CSR 650 H1 cam questions.
I used a Haynes manual to get all the info I needed.
28 Aug 2010 08:26 #394511 by Emberblade
but i still need help, the haynes doesn't tell me how exactly to put the cams in, not to mention the different markings on the cams themselves.
28 Aug 2010 08:42 - 28 Aug 2010 08:46 #394514 by steell
Replied by steell on topic 1981 KZ CSR 650 H1 cam questions.
On the front (exhaust) cam sprocket there will be a straight line and it will say EX next to it. That gets lined up with the front edge of the head.
Rear (intake) cam will say IN with the straight line lined up with the rear edge of the head.
Count the pins on the cam chain starting at the first pin above the straight line on the exhaust cam sprocket. Count 46 pins and the 46th pin should be jest below the straight line on the intake cam sprocket. As a quick check the front (exhaust) EX line will be between two links, the rear (intake) cam sprocket IN line will be in the middle of a link.
T is on the timing advancer and is for TDC.
Haynes manuals don't even make good toilet paper.
Last edit: 28 Aug 2010 08:46 by steell.
28 Aug 2010 10:01 #394530 by rstnick
Replied by rstnick on topic 1981 KZ CSR 650 H1 cam questions.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
28 Aug 2010 14:35 #394589 by Emberblade
another question, what if i can only count to 22 when counting the chain links?
28 Aug 2010 18:17 - 28 Aug 2010 18:20 #394618 by steell
You're not supposed to count links, you're supposed to count pins.
rstnick, you didn't notice that it's an 81 with a link plate (HyVo) chain and not an early model with a roller chain?
The pages you posted cover the early models :)
The give away was when he described the Z6 and Z7 on the cam sprockets :laugh:
I just set up the cams on a 750 for a friend of mine last weekend, so it was still fresh in my mind. Two weeks from now it may not be :)
Last edit: 28 Aug 2010 18:20 by steell.
28 Aug 2010 22:43 #394685 by Emberblade
Wow! thanks for the help. that was really racking my brain.... i will post again if i still have problems. thanks to you all.
28 Aug 2010 22:47 #394686 by Emberblade
i'm feeling really stupid now btw.... :woohoo:
28 Aug 2010 22:55 #394687 by steell
Nope, can't feel stupid unless you bend valves, and you wouldn't believe how easy those valves will bend.
If you screw up, and you feel a "thunk" while gently turning the motor over by hand, you bent at least two valves. And if you then rotate the motor the other way and feel a "thunk" you just bent two more.
29 Aug 2010 08:20 #394757 by Emberblade
well i haven't done that yet thankfully. i know that the valves have proper clearance, because i measured them. i've been doing all right with the repair until the camshaft. but now i hope i can get it right.
