- Thank you received: 104
re-using exhaust gaskets
- stonemaster
- Visitor
27 Aug 2010 16:50 #394358
by stonemaster
re-using exhaust gaskets was created by stonemaster
opinions ? think i may still have a tiny exhaust leak, tested using butane around collars and nothing but I hear a faint ticking after riding a couple of miles that sounds exactly like the much louder version of my previous exhaust leak, I mean exactly the same just quieter. Its not just valve noise either. I used the Suzuki gaskets which pretty muck took care of the major exhaust leak. I did not use Permatex copper on them however , should I re-use?? I do have a set of new copper stock gaskets and some used copper gaskets as well.
- PLUMMEN
27 Aug 2010 17:03 #394362
by PLUMMEN
Replied by PLUMMEN on topic re-using exhaust gaskets
if theyre solid copper gaskets you can heat them with a torch till theyre red hot and toss in a bucket of water and reuse them,if theyre the crimped style like stock kaw gaskets pitch em
- 79MKII
- Love Them Kaws!
- Thank you received: 43
27 Aug 2010 17:09 #394365
by 79MKII
The Kaw List:
Replied by 79MKII on topic re-using exhaust gaskets
Wow, I just walked in from the garage wondering if I can re-use those exhaust gaskets.
If they're crimped type, they'll show a seam, correct?
The Kaw List:
- Motor Head
- Thank you received: 391
27 Aug 2010 17:12 #394367
by Motor Head
Replied by Motor Head on topic re-using exhaust gaskets
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is MY Ebay listing for a bag of 10 gaskets If they will fit yours, or others. Sorry but they come 10 in a bag, not 8 or 12, why?
330464938137
330464938137
- stonemaster
- Visitor
27 Aug 2010 17:17 #394368
by stonemaster
Replied by stonemaster on topic re-using exhaust gaskets
www.z1enterprises.com/detail.aspx?ID=1602
these are what i used last time, they recommend them for aftermarket headers
- Motor Head
27 Aug 2010 17:29 #394376
by Motor Head
Those are great gaskets. I suggest you take a couple feet of some hose, fuel line will work, and place it to your ear, but not in it. Then check for noises, especially around the suspect exhaust. Did you happen to check with a straight edge the header flanges? Torque it down in steps evenly? And a re-torque after a good run?
- stonemaster
- Visitor
27 Aug 2010 17:44 #394379
by stonemaster
all of those, it only shows up after a couple of miles when the engine is good and warm, she's put up for the night so I may do some rechecking tomorrow, the flanges were not all in a line however the one that was really bad (the one with the BAD exhaust leak) I heated and bent back into position.
- Old Man Rock
- Thank you received: 225
27 Aug 2010 17:59 #394384
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic re-using exhaust gaskets
Mike... Visual/confirmation on the seam... YUP!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 79MKII
- Love Them Kaws!
27 Aug 2010 18:53 #394406
by 79MKII
The Kaw List:
Thanks OMR!
Wow, those suzuki gaskets look really nice. I've never tried them. They look like they might be re-usable too? Do they crush? Is there copper inside of them? Is it basically like the Kaw gaskets with the material over it? Can I keep asking questions? When will it stop? Why can't I stop now? Do I have a problem? Can someone help me?
OK, stopped it....
OK, stopped it....
The Kaw List:
- stonemaster
- Visitor
27 Aug 2010 19:01 #394411
by stonemaster
Yea i kinda guessed that would be the case. Like I said i got copper new and old, I read somewhere of someone doubling up using a really flat one with a good one and some copper permatex with excellent results. Cant remember where though
- PaulsKZ1000LTD
31 Aug 2010 18:16 #395264
by PaulsKZ1000LTD
1982 KZ1000 LTD K2. Resurrected, not restored
Replied by PaulsKZ1000LTD on topic re-using exhaust gaskets
I used Suzuki GS550 XN85 GSX-R750 gaskets on my 82 KZ1000 LTD and overtightened the first time. They unwound like a watch spring. Second set used gasket sealer and just tightened them. No leaks and they are less than $2 apiece on Z1. Why would you reuse them?
- stonemaster
- Visitor
01 Sep 2010 15:11 #395457
by stonemaster
by over tight u mean over spec???
