- Thank you received: 10
no return on shifter pedal
- Kitten Tooth
23 Aug 2010 19:06 #393346
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
no return on shifter pedal was created by Kitten Tooth
I was sitting on my 76' KZ400D3 the other day that i am using for the engine in my Kart project. I was rolling the bike back and forth and messing with the shifter pedal. I noticed that when i pushed it down out of neutral into first with my foot, the pedal would stay down and i would have to help it back up with my foot. On my KZ1000, when you push the pedal down to down shift or pop it into 1st to push start it, the pedal re-springs back up by itself.. is this a serious problem with the transmission?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- MFolks
- Thank you received: 540
23 Aug 2010 19:27 #393353
by MFolks
Replied by MFolks on topic no return on shifter pedal
Probably a broken return spring(they wear out from use).
- Kitten Tooth
23 Aug 2010 19:44 #393356
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic no return on shifter pedal
Can i run the motor and can it drive stuff with that broken spring? i can just help it snap back up after i push it down right? or do i need to get into the transmission?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- PLUMMEN
- Thank you received: 104
23 Aug 2010 20:16 #393368
by PLUMMEN
Replied by PLUMMEN on topic no return on shifter pedal
look under sprocket cover
- Kitten Tooth
23 Aug 2010 20:24 #393375
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
under that, there is the shaft that the shifter pedal goes on and i think it just sticks out of the crank case. would it be a pain in the ass to replace that spring? Im gonna look at some parts diagrams too.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
24 Aug 2010 07:11 #393434
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic no return on shifter pedal
If your rolling the bike back and forth, and you click it down into gear as you are still pushing/pulling on the bike, the pedal will stay down. Its normal if the pressure is still there, just roll the bike back/opposite direction and the pedal should pop back up.
The tranny can do this when strained without the input shaft rotating on lots of different bikes/atvs.
If it does not return, even with bike standing still, then yes the spring is probly too worn/broken.
You have to remove the sprocket cover, and then the shifter linkage cover plate that covers the linkage and trans-rod access behind the sprocket.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kitten Tooth
24 Aug 2010 19:28 #393612
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
sweet, i didn't go to the garage today but ill see what happens on thursday when i go down there to clean stuff up.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
