- Thank you received: 10
Best way to test 0 clearance valves?
- timebomb33
I THINK MY POWERBAND BROKE
- staniel
- Thank you received: 5
If that's true, my plan is to go to
(valve. new shim, new clearance)
1. 250, .163
2. 250, .178
3. 240, .176
4. 245, .150?
5. 230, .150?
6. 240, .176
7. 235, .152
8. 235, .150?
Bonus question, how do you get specificity like .15mm in the back and .178 in the front if shims only come in increments of .05mm?
Time for a post in the shim trading thread!
(As for the mechanic, they knew I was on a serious budget, as I brought the head and cylinders in separated from my bike.)
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
- Thank you received: 2098
- staniel
- timebomb33
- staniel
- Jeff.Saunders
I tend to set my own valves a shade wide after the valves are lapped in. So when my target clearance is 4 thou (0.1mm) - I set the valves roughly 5-6 thou (0.125mm-0.15mm) to give room.
Generally the clearances on these bikes will always shrink with wear - so setting clearances at the wide end of the range is not a bad thing.
www.z1enterprises.com
Z1 Ent on Facebook,
- Old Man Rock
- Thank you received: 225
Stock pistons, cams and head work?
As I have learned in my build, due to higher compression pistons, performance cam and P&P head with +1 up valves, she'll run a little hotter then a stocker...
With this in mind, for my build, exhaust runs a tad hotter then normal so instead of spec .05mm - .10mm...
I set my clearance as follows:
.08 to .10mm for the Intake +/-.01mm
.09mm to .13mm for the exhaust +/-.01mm...
As mentioned, after the first 500 miles, found the exhaust side clearances decreased by one shim size....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- Thank you received: 104
:woohoo:One more thing to think about....
OMR
- staniel
2) Is there some trick I don't know about to get tolerances to within .03mm? I mean, shims only come in .05, so how can you specify a range of .09-.13? I mean, in general, the best you can hope for is that all your cams are within .02 or .03 of your ideal, so what does it mean to make the exhaust .02 looser than the intake? The only goal I can really set is between .14mm and .18mm for exhaust and between .12mm and .16m for intake, but I'm still quite likely to have some intakes at .16mm and exhausts at .14mm, right? Am I making any sense?
3) I will certainly be aiming for the high end on all of these. My new clearances should be 0.15mm - 0.17mm (spec on my bike is .08-.18mm) on the ones I can know, and at least 0.13mm for the ones that are at 0 clearance now. I'm expecting to get a couple extra shims just in case. I'll have to install the cams one extra time, but bolting them down three times isn't too bad for one top-end job, right?
- PLUMMEN
the exhuast runs hotter than intake valve on any motor,thats the reason for more clearance.1) You guys are the best.
as valve heats up it expands eating up the extra clearance.
- staniel
I could wind up with my intake valve being at .17mm and all my exhaust being at .14mm, because shimming up or down in either direction would take me out of range.
I realize it's tricky. Given the ranges you guys all specify, it'd sure be nice if shims were in .02mm increments.
