Shifting only into first after chain came off.
- Dan333
20 Aug 2010 13:58 #392541
by Dan333
Shifting only into first after chain came off. was created by Dan333
Hi,
I have a 78 kz650sr, I was stopped at a red light and went to make a left turn and the chain came off the back sprocket. I put a new chain and rear sprocket on and now it only wants to shift into first and neutral. I'm not sure how this happened, but when I was removing the engine sprocket to get the chain off, it spun when the bike was in first gear. Does anyone know what could be wrong?
Thanks,
Dan
Thanks,
Dan
- mark1122
- Keep twisting it
- Thank you received: 109
20 Aug 2010 15:01 - 20 Aug 2010 15:03 #392552
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Shifting only into first after chain came off.
are u actualy moving when u try to shift to second?
or just stasionary? a kz900 will only shift to 2nd while moving.
what moved when u took the chain off?
it should not matter anyways.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 20 Aug 2010 15:03 by mark1122.
