Oil cooler hose repair
  • vintagemcycleguy
  • vintagemcycleguy's Avatar Topic Author
20 Aug 2010 10:26
#392494
I have a 81 GPZ1100 and one of the oil cooler tube is leaking at a crack at the top of the engine. A new one from Kawasaki is 180.00. Is there a good way to repair these things. Thanks.
  • Kawickrice
  • Kawickrice's Avatar
Re: Oil cooler hose repair
20 Aug 2010 10:46
#392500
Try your local auto parts store. Should be alot cheaper than Ma Kaw. You might try Z1E also to see if they can help
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
20 Aug 2010 10:57
#392503
Welcome.
Like said already, you'll probly have the best luck at a hardware/mechanic supply store.
If you call Jeff @ Z1 Enterprises He will steer you right in no time!
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • MFolks
  • MFolks's Avatar
20 Aug 2010 12:38
#392529
When I replaced the oil cooler hoses on my 1982 GPz1100 B2 model, I removed the hoses from the cooler and engine,and carefully used a Dremel tool with a cut off wheel to remove the "Crimp" next to the fittings.
It was then easy to remove the fittings. I found a brand of oil rated hose carried by :http://www.holley.com/types/Pro-Lite%20350%20Hose.asp
I've found that the fuel injection hose clamps(the kind without the "Worm Gear")will treat the hoses better as rubber will not extrude through them.
  • DFIGPZ
  • DFIGPZ's Avatar
20 Aug 2010 18:49
#392606
and more than likely when you would go to order it would would show as discontinued. kawasaki is good about showing pricing then when you go to place the order it shows no longer available.
1984 750 Turbo
  • hocbj23
  • hocbj23's Avatar
20 Aug 2010 18:59
#392614
I good industrial supply store should have Goodyear hoses in red or black that are made for oil cooler application.They should also have barbed fittings that require no clamps. I am running those on my KZ1000 with Satrab oil cooler now for awhile with nary a leak or problem.bj
