Steering stem spanner wrench
- oppie501
19 Aug 2010 08:24 #392123
by oppie501
Steering stem spanner wrench was created by oppie501
Hey guys, I have a 77 kz 1000. I need to properly tighten the steering head nut. The book shows setting the preload on steering stem bearings with a spanner wrench. Anybody know where i can get one? I have seen something similar on e-bay, but was sold as a shock spanner wrench. Are they the same size?
Thanks
Thanks
- TeK9iNe
- What did you do!?!
- Thank you received: 28
19 Aug 2010 08:28 - 19 Aug 2010 08:30 #392125
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Steering stem spanner wrench
The spanner wrench is the "best tool for the job", but you can get away with large channel locks.
They canbe had by just about any mechanic tools place on the net. Eg. Harbor Freight Tools
When things get to tight for the locks, then a flathead screwdriver and a mallet/hammer works fine to "knock" things into the correct place. Stick the driver in the notches and tap it around... dont forget to change notches as you go.
Setting steering stem resistance is a feel thing anyways.
I like to get it slightly tighter than most. The bars still fall "lock - to - lock", but it takes just a slight more slide for me.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 19 Aug 2010 08:30 by TeK9iNe.
