Hickup in 2nd gear
- brianrae33
17 Aug 2010 07:56 #391625
by brianrae33
1982 kz1000ltd
Hickup in 2nd gear was created by brianrae33
Bike is an 82kz1000..when shifting into 2nd gear on occasion i'll get a small hickup after just getting into the gear...but it stays in gear even when you tromp on it...no issues after that...at first a thought it may be a bad shift fork...but wouldn't it pop out under load if that were it?? It only does it under little throttle..almost feels like the chain jumps a tooth but it doesn't appear so...Any thoughts??
1982 kz1000ltd
- PLUMMEN
- Thank you received: 104
17 Aug 2010 08:10 #391631
by PLUMMEN
Replied by PLUMMEN on topic Hickup in 2nd gear
check your shifter and linkage
- TeK9iNe
- What did you do!?!
- Thank you received: 28
17 Aug 2010 08:18 #391639
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Hickup in 2nd gear
PLUMMEN wrote:
+1
Perform all of the maintenece items in your MANUAL. :laugh:
GL.
+1
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
