clutch cable adjustment procedure
- djm2475
16 Aug 2010 23:43
Could someone please tell me the proper procedure on adjusting the clutch cable? Mine recently broke and I ordered one from Z1. Thanks.
- H1Vindicator
Last edit: 21 Feb 2013 20:47 by H1Vindicator.
- Link14
Re: clutch cable adjustment procedure
17 Aug 2010 08:57
Yep...need to know which bike you have first.
- RonKZ650
17 Aug 2010 09:45
Just put the cable on and adjust the adjuster midway on the cable and the lever for proper free play at the lever and you're all done. If the clutch was working with the old cable it will work fine with the new without botching up the engine push rod adjuster 99% of the time.
- H1Vindicator
17 Aug 2010 12:12 - 17 Aug 2010 12:14
RonKZ650 wrote:
Yes, simply replacing a broken clutch cable should have no effect on the existing clutch push rod adjustment.
Clutch push rod adjustment -- Need and Purpose
[This is a 1 minute job from start to finish, maybe 2 minutes the first time.]
The FSM covering Z1 and KZ900 includes a periodic maintenance chart requiring clutch push rod adjustment at 2000 mile (3000 km) intervals and explains the need therefor in separate text, which explanation is quoted verbatim as follows:
Besides cable stretch, clutch plate wear also causes the clutch to go out of adjustment, with a decrease in push rod play. Due to this wear, the push rod gradually moves closer to the clutch release lever (at the lower end of the clutch cable) until it touches the adjusting screw. When the rod is touching the screw and therefore has no play, the clutch will not engage fully and clutch slippage will occur. Note that the clutch push rod does not necessarily have play just because the clutch hand lever has play, and so hand lever play alone cannot be used to determine whether or not the clutch requires adjustment.
The FSM covering '77-'79 KZ1000's includes a periodic maintenance chart requiring clutch adjustment at 5000 km intervals, and explains the need therefor in slightly different language, which explanation is quoted verbatim as follows:
Clutch plate wear also causes the clutch to go out of adjustment. This wear causes the play between the push rod and the adjusting screw to gradually diminish until the push rod touches the adjusting screw. When this play is lost, the clutch will not engage fully, causing the clutch to slip.
NOTE: Even though the proper amount of play exists at the clutch lever, clutch lever play alone cannot be used to determine whether or not the clutch requires adjustment.
While the clutch may indeed be worn out with plates needing replacement, it isn't uncommon to overlook or be unaware of the clutch pushrod adjustment feature, especially without a manual. It is worrisome to see anyone of unknown experience, without a manual or failing to consult a manual, proceed with clutch disassembly and plate replacement, without first being aware of and considering the clutch pushrod adjustment.
Where both (1) clutch cable slack adjustment is perfect, and (2) clutch pushrod adjustment is perfect, and the clutch still slips, suspicion is certainly toward the plates being worn and needing replacement. But other things can also cause slippage, even with proper adjustments and good plates, such as glazed plates or improper oil being used in the crankcase.
Last edit: 17 Aug 2010 12:14 by Patton.
17 Aug 2010 12:20 - 17 Aug 2010 12:22
Last edit: 17 Aug 2010 12:22 by Patton.
17 Aug 2010 12:24
Another page from the original 1973 Z1 OWNER'S MANUAL.
[Click on image to enlarge view.]
17 Aug 2010 12:25
Yet another page from the original 1973 Z1 OWNER'S MANUAL.
- djm2475
17 Aug 2010 14:11
Thanks for all the help so far. i was not aware that the models made a difference. i have a 1980 KZ1000 that i just purchased. plenty of mods have been done to this bike,ported j head,cams, carbs and kerker pipe.
