- Thank you received: 543
Octane rating for 810 motor?
- Injected
16 Aug 2010 11:09 #391394
by Injected
Octane rating for 810 motor? was created by Injected
I was wondering if anybody out there that was running an 810cc kit in there 650 could tell me what octane fuel they have been using... and in particular if they are using an oil cooler?
I am asking because I am building a similar motor... want to run without a cooler if possible.
Would like to know if I should try and drop my static compression ratio... right now at 9.9:1 and I can alter that pretty easy.
I don't mind running premium gas if that's what it will take.
- T_Dub
- Thank you received: 25
16 Aug 2010 13:02 #391430
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Octane rating for 810 motor?
You should use premium in the compression that this motor is supposed to have.
I have mine built, but have not run it yet so I can't give you concrete info. But I'm going to be using an oil cooler, I just think its a good way to protect our investment.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Mark Wing
- Thank you received: 22
16 Aug 2010 13:20 #391434
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Octane rating for 810 motor?
I run premium and a oil cooler.
Mark
Mark
Yorba Linda Cal.
- Injected
16 Aug 2010 15:33 #391458
by Injected
Replied by Injected on topic Octane rating for 810 motor?
Thanks Mark.
I ran almost the same combo with a cooler back in 1990...
I am again running those same pistons but they have been modified by lowering the dome and bigger valve pockets than in 1990. I must have been about 11:1 then, but never really bothered to CC anything - just stuck it in and ran it!
I just CC'd them with the head I am going to use which has the valve seats sunk and de-shrouded.
Pistons are old MTC 831cc units, current combo has ported head with stock valves flowing 25% more air than stock, Andrews 20 cams, and VM26 carbs from a KZ1000. Going to run stock air box and dual exhaust.
I don't want to run a cooler because I want it to look stock - I am not going to put a ton of miles on it... it's going to be a Saturday Nite Special.
I am in Canada, so it is a bit cooler here.
I was pretty sure I could get by on 91 octane and if it pings I will try and find some 94 or use some booster... just could not remember what I was running back then!
- mark1122
- Keep twisting it
- Thank you received: 109
18 Aug 2010 08:34 #391885
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Octane rating for 810 motor?
10:1 is normally ok on the kz900 motors, i dont see why this would be any dif. the only thing that would be an issue would be the extra heat and small duration cams.
i run 91 on my 1200cc bike so u should be fine. if u have a ping u could try a cooler then.
u could run a tighter squish to improve the burn and help prevent stagnation at the outer edge of the cyl. Also make sure u massage any sharp edges from those pistons and there valve pockets.
does the 650 run a shell main bearing or a needle?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- steell
18 Aug 2010 13:32 #391933
by steell
Replied by steell on topic Octane rating for 810 motor?
Bearing shells, the big motors (900 and up) are the only ones with roller bearings (don't know about the Z2 though).
- mark1122
- Keep twisting it
19 Aug 2010 05:44 #392084
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
u can run .040" squish on a kz900 with rollers. a kz with shells should be able to run even tighter.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
